Closed Thread
Old 10-26-2009, 11:12 AM   #301
big_al_71
big_al_71's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
That blue truck looks awesome.....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline
Old 10-26-2009, 01:11 PM   #302
jorgensensc
jorgensensc's Avatar
Benji,
Looks good, but I have a question. In the picture you show of the spacer, the spacer is off center of the rotor (due to the slotting of the spacer holes). How do you ensure that the spacer is centered when mounting the wheels? It seems that the front would have an unbalancing if the spacer isn't centered carefully. What did you do to make sure the spacer was centered?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline
Old 10-26-2009, 01:17 PM   #303
lolife99
67-72 parts collector,…
lolife99's Avatar
Very nice looking truck, Benji.
What size tires are you running?
Keith
Convert to disc brakes.
lolife99 is offline
Old 10-26-2009, 02:05 PM   #304
Benji_1802
Well i centered the spacer on the rotor and used a special glue, forgot the name of it, but once you bolt on the wheel the spacer goes no where. As far as tires, im running 275-40-20 on the rear and 255-35-20 in front, i still need to cut the front fenders and modify my bed to go lower when i slam the bags, but thanks for all the comments guys..
Benji_1802 is offline
Old 10-26-2009, 05:30 PM   #305
nlped
nlped's Avatar
Hey Benji, your truck looks GREAT!!!
And you can use Gorilla Snot to hold the spacer in place...I've used it with great success.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 10-26-2009, 07:05 PM   #306
DrtyJack75
any pictures of your rotors before/after you shaved them down? How much does something like this cost to do?
MAN I WANT THESE WHEELS EVEN MORE NOW!!
DrtyJack75 is offline
Old 10-26-2009, 08:39 PM   #307
VA72C10
VA72C10
VA72C10's Avatar
Liking them more and more...can't wait till they're out in chrome fixed for our trucks!!!
VA72C10 is offline
Old 10-30-2009, 06:34 PM   #308
duceducenine
duceducenine's Avatar
what up ben just saw the truck on the 20's
looks real good...hows the setup working?
if you got any q's let me know!
duceducenine is offline
Old 10-30-2009, 07:05 PM   #309
Benji_1802
hey Jay.! whats going on? yea ended up looking pretty good. The set-up is working good so far, i have a few leaks on the back, but the front has been perfect no leaks at all. Real happy, good job man. My boy might be giving you a call soon about his blazer that he wants to bag..
Old 10-30-2009, 07:12 PM   #310
weircc
weircc's Avatar
just wanna comment on them spacers i would highly recommend you check lug nuts often i had these same ones mr gasket ones correct me if im wrong you are just asking for trouble mine came loose several times they make ones where the bolt pattern is correct your truck is bad azz wouldnt want to see it tore up
weircc is offline
Old 10-31-2009, 09:09 AM   #311
SANCHO
Man Benji..... You have an amazing looking truck. Thanks for posting pics, time to get off my ass and get some work done now.
SANCHO is offline
Old 11-01-2009, 11:05 PM   #312
Sydwayz
Hi folks, FNG here in Virginia. I found the forum by searching on the (black) Boss 338 wheels.
I just bought this 1997 Tahoe, and from what I gather; I could have a problem trying to get the Boss 338 18x8 to fit on my front axle; correct?
I am going to do 18x8s all the way around as I plan for this truck to be a driver with a lot of rubber on each corner.
I just ordered a single 18x8 through a friend of mine & a set of 4 knock-offs. (They are only sold in a set of 4.) I plan to do some test fitting with the one wheel. I have BellTech drop spindles and drop springs, but the drop springs are coming off this week and stock spring are going back in. I don't want the raked look.
Does anyone have any more info or experience they can share? Thanks in advance!
Sydwayz is offline
Old 11-02-2009, 11:49 AM   #313
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Sorry no help but VERY nice looking Blazer!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 11-02-2009, 11:59 AM   #314
brossow
Amateur Rust Fighter
brossow's Avatar
That's correct, unless somehow you get "lucky" and have different rotors than everyone else. The design is being reworked to open up the back, but now it's been pushed back until later this month. I'd hold off until you can be sure you're getting the new design for all four corners (rather than buying two now for the back, for example, which would prevent you from rotating your tires in the future).
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 11-02-2009, 12:55 PM   #315
djracer
djracer's Avatar
welcome to the board from Alabama.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline
Old 11-02-2009, 01:42 PM   #316
Strut
Strut's Avatar
Benji_1802
What size tires are you running on the wheels?
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline
Old 11-02-2009, 03:38 PM   #317
DZL1
One day.....
DZL1's Avatar
Nice Blazer!!
DZL1.
DZL1 is offline
Old 11-02-2009, 04:52 PM   #318
lolife99
lolife99's Avatar
Originally Posted by Strut View Post
Benji_1802
Keith
lolife99 is offline
Old 11-02-2009, 05:36 PM   #319
nlped
nlped's Avatar
^^^What he said!
Carter
nlped is offline
Old 11-02-2009, 07:31 PM   #320
bad68bowtie
On the college boy budget...
bad68bowtie's Avatar
Not completely relevant, or the best picture, but my sister saw this car when she was in Asheville this weekend and snapped a pic of it. I was looking at the picture and noticed the wheels looked like Boss 338s so I figured I'd post it.
-'68 C10 short/step- 350/350
bad68bowtie is offline
Old 11-07-2009, 02:37 AM   #321
Jbham88
Jbham88's Avatar
any updates as to when the retooled wheels are being released??
1986 GMC 4x4
Jbham88 is offline
Old 11-07-2009, 10:55 AM   #322
nlped
nlped's Avatar
Still looking at the end of this month.
Carter
nlped is offline
Old 11-09-2009, 07:45 PM   #323
r1lorenzini
20's with a 45 series is plenty of meat to drive every day imo
r1lorenzini is offline
Old 11-09-2009, 07:49 PM   #324
SCOTI
SCOTI's Avatar
That's also a tall combination. Many trucks, even w/just a static 5/7" drop can only go about 28" tall on the fronts which is a 245~255/40-20.
45-series rubber on 18's will work on most set-ups if 18" wheels are acceptable.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 11-10-2009, 02:07 AM   #325
r1lorenzini
Well I can only speak from experience where as I have his drop and the size tires I recomended and I have no problems what so ever rubbing or
ride quality like I said
just IMO
Closed Thread
