Old 11-02-2009, 02:12 PM   #1
cleszkie
cleszkie's Avatar
Major Junkyard Score!!
I went to my local Ecology pick and pull last weekend looking for an open carrier for a 14 bolt axle. I found the carrier in a 1988 Suburban which also happened to have a Gear Vendors overdrive unit still installed! The Sub was 2-wheel drive with a big block and TH400 tranny, so I will have to buy the NP205 adapter to install it in my 72 K5 Blazer, but that is peanuts compared to the cost of one of these units new (about $2,800). I got all of the wiring, switches, CPU, and speedo cable adapters. The best part is that I got it all for $100 (the cashier didn't know what it was, so she charged me the standard price for a transfer case).
I have been looking at these things for years, but never got the cahones up to lay down the cash for one, and the ones on ebay always end up going for a mint as well. I have also been putting off a 700R swap due to the cost of building a good tranny and buying an adapter to retain my NP205. Now I can spend a fraction of the cash and bolt this thing up.
Sorry for the long post, but my wife just didn't fully appreciate my find and I needed to share with those that would.
cleszkie is offline   Reply With Quote
Old 11-02-2009, 02:18 PM   #2
truckster
truckster's Avatar
Re: Major Junkyard Score!!
That is incredibly cool!
And no, wives don't understand junkyard scores. "But, honey, you don't understand how rare this is." "Uh-huh. That's nice. Have you mowed the lawn yet?"
I'm very happy for you. It should really be a nice addition to your Blazer.
truckster is offline   Reply With Quote
Old 11-02-2009, 05:46 PM   #3
WHAMMYBAR66
WHAMMYBAR66's Avatar
awesome find !
WHAMMYBAR66 is offline   Reply With Quote
Old 11-02-2009, 08:27 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
Nice! BUT....
Sorry I guess it's not "worthless" without them...but it would be alot cooler with them.
Has anyone every put these in a 4x4 blazer? Is it short enough to not cause problems on our wheelbase???
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-02-2009, 09:25 PM   #5
watahyahknow
watahyahknow's Avatar
wow i only heared about a simulair junkyard find once and that turned out to be a pretty good find
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-02-2009, 09:42 PM   #6
cleszkie
cleszkie's Avatar
I contacted Gear Vendors to get info on swapping out the adapters to make the unit work on my NP205. It will cost me $550 in the end to get the proper adapter ($550 for the adapter and coupler plus a $250 core charge that I will get back when I send them the TH400 adapter and coupler that I now have). So I will then have $650 into the unit. I figure it will be another $200 to have my existing CV driveshaft shortened for a grand total of about $850. Nothing to sneeze at, especially in this economy, but still less than a new unit.
The tech staff at Gear Vendors are concerned that the additional 14 inches of length that the unit will take up will make for a pretty short rear driveshaft, and that the angle will be fairly steep with the 6 inch lift I have. I assured them that I would take steps to help this out by lowering the transfercase within the existing cross member, and rotating the perches on my rear axle to make sure the pinion is pointing right at the overdrive output shaft (the best condition for a CV joint on the transfercase end). I run electric fans, so tilting the engine back should not cause any fan/shroud interference issues.
I will take some pics tonite for those that are interested. I am a firm believer in the old saying that if there are no pictures, it didn't happen!
Old 11-02-2009, 09:49 PM   #7
watahyahknow
check ebay for the adapter no way a piece of aluminium is worth that mush aspecially when you need to trade in the piece you have
Old 11-03-2009, 07:35 AM   #8
vtblazer
vtblazer's Avatar
When I ran mine in a 72 long bed 4x4 I did a lot of u-joint research (sorry lost the web-site) and found that u-joints 'should not' be pointed directly at each other , some degree of offset is needed.
Both angles 'must' be the same as well, other-wise you'll have vibration.
I ended up with a pretty short rear shaft even in the long bed, good luck stuffing it under your blazer.
I've still got some pics of the install if they might help ya out.
vtblazer is offline   Reply With Quote
Old 11-03-2009, 07:40 PM   #9
cleszkie
cleszkie's Avatar
vtblazer -
I agree with you in that the angle of the driveshaft needs to be the same at both ends of the shaft if you are running a non-CV driveshaft in order to cancel vibration (tranny/transfer case output shaft should be parallel to the rear differential pinion). However, if you run a driveshaft with a CV joint on the transfer case end of the driveshaft (like I am running), the pinion should be pointed directly at the tranny/transfer case output shaft. In this way, the CV joint maintains "constant velocity" through the bend, and there is no variable velocity vibration through the aligned u-joint at the pinion end since the angle is essentially zero.
I don't disgree that installing the unit will be a challenge, and that the driveshaft will be short, but this rig sees alot of highway miles and not so many twisty trails, so the benifits will outweight the problems in the end.
Old 11-03-2009, 08:08 PM   #10
vtblazer
vtblazer's Avatar
Good thread to watch for sure.
...and your correct, CV's & u-joints are different all together.
My blazer that had a doubler set up needed a CV off the rear t-case too, I believe if two t-cases can be run succesfully back to back, so couldn't an over drive unit.
Old 11-04-2009, 08:30 PM   #11
Jtrux
I'm a poor spectator
Jtrux's Avatar
Wow!!!!!!!!!!! That's awesome, really happy for you. I can't wait to see how it turns out. I would hesitate to lower the xfercase. Just doesn't seem like a good idea. Contact a compentant driveshaft shop and see what they say, it might cost some coin but I be they can fix you up. Have you ever seen a Jeep Wrangler driveshaft? They are like 18 inches long with a double cv.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 11-04-2009, 08:40 PM   #12
swyfor5
swyfor5's Avatar
Nice find, but just have to add-include the wifey in ALL the details and it pay's off in the long run! Mine loves it all with the k5, except for the spent cash! She is my number one supporter for this project, and couldn't do it without her.
swyfor5 is offline   Reply With Quote
Old 11-04-2009, 11:35 PM   #13
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
How Cool!
If I were running an automatic, I would so get a Gear Vendor unit. The GV is unbreakable and the service from those guys is first rate.
Tom Vogel is offline   Reply With Quote
