60-66 Nut
Re: Hei c
What I've done is trace the original ignition wire (the one that went to the coil) all the way back to the ignition switch. I then replaced that with a 12ga wire all the way to the distributor. The factory typically used a pink colored wire for this. You need to be sure that you have a full 12 volts to the HEI.
| Bookmarks |
