Readend saddle change
I have a 12 bolt rearend on my 63 with 6 lug axles trailing arm/coil suspension. On my 79 donor truck i have a 12 bolt rearend (littlebit wider) with leaf springs.
The question is has anyone here cut off thesaddles and panhard bar mount from a complete rear end and transfered them to another axle. Is this possible or not recommended. Do i have to buy new saddles and mount. Thoughts/examples/ picture? Jory
Rods
![]() Join Date: Nov 2002
Re: Readend saddle change
yeah its not that big of a deal. you can get a cheap angle finder and mesasure your 66 axle. then weld the saddles onto the 79 at the same angle.
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
60-66 Nut
Yeah, it's not too difficult to do. You just need to make sure your pinion angle is correct.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've done it a few times. Recently, I did one for a 63 I am building. There are pictures in my blog.
I'm at work right now and Photobucket and my blog are both locked out of these computers. I will post my pictures tomorrow when I get home to my computer.
All I do it cut the brackets and saddles off the axle tubes, set it into place on the new ECE saddles, center, set pinion angle and weld them on. Nothing to it.
Roadhammer, here are the pictures. It's an 80 model rearend. I ground all of the old brackets and spring pads off then welded the ECE saddles into place.
| Bookmarks |
