Old 11-04-2009, 03:58 PM   #1
Mike J
vw guy & now c-10 guy
Mike J's Avatar
Question Front lowered! finally
Ok, I'm a jacka$$, I tore the front end of my '68 completely down to the crossmember a few months ago, and am getting ready to start the rebuild FINALLY. Have all new parts BUT, here's the problem, I accidentally dumped all of my nuts and bolts in the floor/kicked 'em around etc. - This is my first Chevy, and first American vehicle, so I'm not too keen on what goes where and what to look for at the hardware store. I want to replace ALL hardware- does someone make a kit for this? or does anyone have a list or diagram or what goes where? Its a 68 6cyl. 1/2 ton fleet with manual steering. Doing drop spindles/disks and power brakes as well. any and all help is appreciated. I live an hour from my the truck and my tools now, so I'm trying to get a gameplan together to get this project rolling again. thanks guys!!!
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 11-04-2009, 04:13 PM   #2
jdcole
jdcole's Avatar
Re: Front Suspension Bolts
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=140
1969 Chevy LWB 350 converting to short stepper
My build thread
jdcole is offline   Reply With Quote
Old 11-04-2009, 04:37 PM   #3
tinkerdad
#8 in the diagram will not fit if you buy it from LMC. You can get it from a Chevy dealership.
tinkerdad is offline   Reply With Quote
Old 11-04-2009, 09:37 PM   #4
Mike J
Mike J's Avatar
Thanks guys! Didnt even think about using the LMC catalog! dub!
'68 long fleet
My Build Thread
Old 11-04-2009, 09:44 PM   #5
jdcole
jdcole's Avatar
Always a good reference but don't take it as gospel. I still cant get my column back together using it.
My build thread
Old 11-05-2009, 02:03 PM   #6
my67c20
Like you everything went in a bucket. When i tore it down i intended to replace all the bolts for the front end, crossmember, motor mounts. To date i have bought about $100 worth of grade 8 bolts from the hardware store. What i found was that most of the stuff was 3/8 or 1/2. What i did was went to the store bought myself a few of the cheapest bolts, washers and nuts in 3" & 2" length. Make sure they are fully threaded. Then as i started to put stuff together i would bolt it together with the cheap stuff to get a length that made sense. Measured that wrote it down and went to the hardware store. Prefit the flat and lock washers, I found that if you went one size smaller they fit better. Make sure to use grade 8 stuff and torque them down. You can go on line and find torque specs for all the sizes and grades. Most important is to take your time and get the right size so it looks good when done.
my67c20 is offline   Reply With Quote
Old 11-05-2009, 11:22 PM   #7
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Yea, I concur with My67c20. It's best to use high quality hardware as you sure don't want anything breaking while you're going down the road.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-05-2009, 11:30 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I use a ton of new grade 8 hardware on all of my builds. You can buy all your grade 8 hardware at your local Tractor Supply for 3.99 a pound in bulk. You can buy a whole lots of grade 8 nuts, bolts, and washers for 20 bucks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-06-2009, 09:16 AM   #9
Mike J
Mike J's Avatar
yeah, I definitely plan on using grade 8 for sure. and there's a Tractor Supply where I live now so that's probably what I'll do. Probably would be really expensive buying each bolt at Lowe's or something! Thanks again guys!!!
'68 long fleet
My Build Thread
Old 11-06-2009, 10:09 AM   #10
lks dcvn
lks dcvn's Avatar
agree with the TSC purchase - I am now on a first name basis with the cashier at my local store -
lks dcvn is offline   Reply With Quote
Old 11-06-2009, 11:25 PM   #11
Mike J
Mike J's Avatar
well, i got passenger front corner almost totally done tonight after work- and man i'm beat! gonna tackle the other side tomorrow, wish me luck!
'68 long fleet
My Build Thread
Old 11-09-2009, 09:20 AM   #12
Mike J
Mike J's Avatar
I finally made some real progress this weekend!!!
'68 long fleet
My Build Thread
