Closed Thread
Old 11-09-2009, 07:02 PM   #176
creep
Registered Loser
creep's Avatar
Re: What did you do to your truck today?
The Holley 500 is an easy swap. If I can do it anyone can. You will need to get an adapter to bolt it in. I'll try to post some pics a little later.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline
Old 11-09-2009, 07:20 PM   #177
creep
Registered Loser
creep's Avatar
You can see more about it in my thread http://67-72chevytrucks.com/vboard/s...d.php?t=354432
creep is offline
Old 11-09-2009, 08:49 PM   #178
sams60gmc
sams60gmc's Avatar
Pulled the beds off the trailer flipped them over on a pallet and collected the money for one of them. Put them away and sprayed the bolts with rust penetrating stuff so I can pull the planks off later this week.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 11-09-2009, 10:06 PM   #179
scotts62
One day...
scotts62's Avatar
Got the fuel pump changed, put new drive line in and fired up my 92 Xcab
Scott
93 crew cab build
Project 62
scotts62 is offline
Old 11-10-2009, 12:39 AM   #180
Rusteeze64GB
rearranged some of the pins on my engine harness and hooked the battery up to see if I could get her to turn. She turns over nicely. I need to get some new head lights and bulbs so I can check to make sure everything works.
Rusteeze64GB is offline
Old 11-10-2009, 08:29 PM   #181
sams60gmc
sams60gmc's Avatar
Layed upder it for a while. Tried to figure out other ways to shorten the frame. Think I got carried away because the new plans are chopping it off behind the cab and fabbing up a new backhalf with C notches and bags.
Old 11-10-2009, 08:39 PM   #182
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Dreamed it was done.
Alan's Classic is offline
Old 11-10-2009, 08:43 PM   #183
198plus
198plus's Avatar
I'm with you Alan..........Think I'll go back to sleep
198plus is offline
Old 11-10-2009, 09:54 PM   #184
JRBECK64
Almost started my Sons 64 on fire today. Was starting it and it back fired and flames were shooting out the carb. Need to fine tune the Timing. Looks like that will be tomorrows job.
JRBECK64
JRBECK64 is offline
Old 11-10-2009, 10:42 PM   #185
63deluxfleet
63deluxfleet's Avatar
well. i washed her up today and i found a great spot by my house to take pictures so i capitalized on the photo op i think i did a good job for a rookie photographer!
go to my album i have 70+ pics http://s49.photobucket.com/albums/f2...CHEVY%20TRUCK/
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield
.......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS.....
63deluxfleet is offline
Old 11-10-2009, 11:34 PM   #186
Slow Build
Slow Build's Avatar
Nice work Isaac. I'm really liking the 63 cab look. The knee knockers scared me away.
Lookin good.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 11-11-2009, 12:22 AM   #187
scotts62
One day...
scotts62's Avatar
Cool pics 63deluxfleet! i like this one the best
Scott
93 crew cab build
Project 62
scotts62 is offline
Old 11-11-2009, 01:33 AM   #188
AZ Chev Man
Rebuilt Carb
Took it for a test drive
Cussed at it as it coasted though my driveway as it wont start again....
AZ Chev Man is offline
Old 11-11-2009, 01:51 AM   #189
bubba327
HOW long until spring??
bubba327's Avatar
Mounted the transmission cooler and cooler lines. Then tried to make the kick-down cable reach and wished I could get it connected to the existing carb on the Inline six... Anybody have a turbo 350 behind a six cylinder and stock one barrel carb???
PLEASE send me a PM with how you hooked up the detent kick-down cable!!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline
Old 11-11-2009, 10:44 PM   #190
DPowers
One foot in front of the other
DPowers's Avatar
Completed my carb linkage, put my driveshaft together and started it up- just to hear it run.
DPowers is offline
Old 11-11-2009, 10:52 PM   #191
Byronic
The Beach Cruiser
Byronic's Avatar
I have the same set up and can't get mine to reach. I'm still working on a solution.
1999 Silverado DD
1966 Panel Truck
2003 Harley Road Glide
1967 Schwinn Tandem Single Speed
Byronic is offline
Old 11-11-2009, 10:52 PM   #192
AZ Chev Man
replaced accelerator pump and it started and got me to a job and back home, still runs bad...bypass fuel pump with electric fuel pump to make sure it was not the problem....IT wasn't
AZ Chev Man
1st Ride 1958 Chevy Apache
2nd 1972 C10
1968 Chevy P10 Step Van
'01 Blazer, '03 Astro
Old 11-12-2009, 12:53 AM   #193
originalJD
James
originalJD's Avatar
I put a new starter in today. I'm alittle scared though. I might have torqued the bolts just a little too much. So far it's workin great.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end.
http://viewmorepics.myspace.com/inde...lbumId=1709080
http://s258.photobucket.com/albums/h...e_top_view_all
originalJD is offline
Old 11-12-2009, 10:48 AM   #194
DPowers
DPowers's Avatar
Is your filter clogged???
DPowers is offline
Old 11-12-2009, 11:45 AM   #195
70 Suburban
Rods
check for a vaccume leak.... try starting fluid rpms raise or wd40 rpms drop around the base of the carb and around the intake.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline
Old 11-13-2009, 01:24 AM   #196
SCOTI
SCOTI's Avatar
Originally Posted by Tx Firefighter View Post
I got a used engine and trans for my quick build 63 farm truck.
Tx, did you get it installed? Any issues?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 11-13-2009, 08:15 AM   #197
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I took an extra day to clean it up and paint it. I installed it yesterday. Today will finish hooking it all up, detail wiring and such.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline
Old 11-13-2009, 10:26 AM   #198
rgCarGuy
My ebay truck came in the middle of the night!
rgCarGuy is offline
Old 11-13-2009, 10:43 AM   #199
jbgroby
jbgroby's Avatar
Gee Virginia there is a SANTA CLAUSE!
jbgroby is offline
Old 11-13-2009, 10:49 AM   #200
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Went down to the DMV...and finally registered my truck....
The frickin 'Governator' took $226 of my hard earned money for that thing !!
And the tag is only good untill FEB !!
Man the lady at the counter real had a hard time...this truck came with the DMV paper all printed up from the guy.
However the OG owner donated to charity, then this guy bought it (owns a lot), then I got it.
So the pink was signed 3 times, we had 3 transfer forms....it had her going crazy !!
Now, I just got it get it running !!
So far...that little truck in my avatar has cost me $600 + $226 = $826
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline
Closed Thread
