Body lifts on these trucks
Hey,
Was wondering if i could see some pictures of people with body lifts, 2-3 inchs. Does it look goofy? can you see the frame rails alot like the 89-98 trucks? will i need to lengthen my steering or ebrake cables?
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
Slots go on anything!
Re: Body lifts on these trucks
It's just my opinion, but yes on all questions. You don't see a lot of people that take the time to put in a body lift correctly. I think a suspension lift is easier to do, but that's just my opinion.
It followed me home?
here is my old 73 with a 2" body lift and 285's, I hated beaing able to see the gap between the frame and body, and the rear bumper hung really low. Suspension lifts are cheap for these trucks, I would go with a 2-3" suspension lift personally
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 11-10-2009 at 10:40 AM. |
huh ???
Here's my blazer with a 3 inch body lift. I'm taking it out as soon as I get all the stock length bolts...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
3" body lift only
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
I have a 3" body lift on my cc.Dont like the fact that the fuel tanks hang down were you can see them.
Ok, well i have a 4 inch lift on my jimmy,leafs no blocks, i just want to get a little 2 more inch's for looks and so it will look better iwth a bigger tire. Instead of getting new leafs up front and a block in back.
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's Last edited by Hoffman65burb; 11-10-2009 at 07:28 PM. |
Jonny
If done RIGHT, it can look good. I have put alot of thought into body lifting mine and here's my plan when I get the time. After installing the lift, move the gas tanks up to where they are still hidden by the body or install a suburban tank behind the rear axle and relocate the fuel door.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
![]() Looks pretty good IMO either way -body or susp
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end" |
