Bleeding Brakes
Searched a little and didnt find anyine with the same issue.
Im trying to bleed my newly run brakes. 1979 disks and crossmember in front and old drums in back. 1979 dual master cylinder up front. Ive had success in the back both old rusty valves opened and allow brake fluid to exit and even squirt out so they work, but the front valves were full of rust so i cleaned them out so they could breath and they still wont let any fluid come out. as far as i can tell i have had no fluid leave the front cylinder resevior at all. Dont know why this would be. I installed all new lines for the front brakes(used old hoses but they worked fine before i drove the 1979 600 miles home with those brakelines. The only think i can think of is that the proportioning valve might be cutting off the flow but i only have a ver limitted knowledge of how those work. any ideas? Jory ![]() |
Re: Bleeding Brakes
Found it button on the front needs to be held in ...thanks anyway..
someone can delete this if they like... Jory ![]() |
HOW long until spring??
![]() Join Date: Mar 2009
Re: Bleeding Brakes
First; Are you using a new master cylinder? if so, did you bench bleed it before installing it?
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
Re: Bleeding Brakes
Re: Bleeding Brakes
Bench bleeding is removing all the air from the master cylinder before you install it in the truck, Clamp the master cylinder in a vise, pipe each outlet line back into the master cylinder side that it started from,(plastic tubing works fine) And gently push in with a dowel or phillips screwdriver "priming " the master cylinder and removing all the air from it first. 15 -50 strokes and until no bubbles are left. When you put it in the truck, you can bleed the lines but DO NOT let the master go dry or you have to start over.
Good luck It is not hard, go slow and be patient. Sometimes bleeding brakes takes awhile.
Re: Bleeding Brakes
Did you get your front brakes bled? If so what did you do? I'm having the same problem on a 75 C10.
I replaced the MC, front calipers, rear cylinders, and the rear steel lines starting at the front of the bed. I get fluid coming out of the rear cylinders but nothing from the front. I did bench bleed the MC before installing. |
#7 | |
Re: Bleeding Brakes
Jory ![]() |
Re: Bleeding Brakes
Thanks Jory. I'm thinking mine has a different problem. I get fluid when I crack open the line coming off the MC for the front brakes but nothing at the calipers.
![]() Join Date: Nov 2006
Re: Bleeding Brakes
TjBlue,
Did you replace your front rubber hoses? |
Re: Bleeding Brakes
I have not replaced the front hoses. I've read different threads to where that fixed front bleeding issues and maybe that's also my problem.
I have loaded a small oil can with brake fluid and connected it to the opened right front bleeder valve. I was able to pump fluid into the line but no air bubbles nor did the fluid level change in the MC and there are no leaks. I'm wondering if the proportional valve could have the front blocked off? It looks tough to get to on this 75. Thanks for the help Andrew. Sorry Jory, I didn't mean to Hi-Jack your thread. Tj |
Re: Bleeding Brakes
Tj[/QUOTE] Dont worry about it i fixed my problem...your thread now. LOL Jory ![]() |
