11-13-2009, 12:47 PM | #1 |
78 brakes
im installing my 3" spindles today and took off the cailpers i noticed while building my truck i didnt have any brake besides the rear which needed to be adjusted so i thought i would step on the pedal with just the front hose coming from the lines and not attached to the calipers and NO brake fuild comes out !! i have fuild to the rear but not the front i also removed the hydroboost from the truck and installed a 1984 booster and master i had some one step on the pedal while i cracked the lines to bleed the master a few times !!!
oh i should add that when i brought the truck it didnt have the engine in it and the brakes didnt work !!! i dont know if its the proposioning block in the front?????? is there something to check im sure if i stood on the brake pedal fuild should flow out!!!!!! |
11-13-2009, 02:17 PM | #2 |
Re: 78 brakes
The line or prop. valve could be pugged up. You could just have a bad brake hose too.
I can still count my vehicles on two... wait three hands. |
11-13-2009, 04:40 PM | #3 |
Dually Pride
Re: 78 brakes
dont trust those brake hoses, i fought with front brakes, even bought a proportioning valve, when all i needed was a damn hose
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
11-13-2009, 07:07 PM | #4 | |
Re: 78 brakes
also i need to bleed the master again it ran dry what would the best way to bleed the air out!! |
11-13-2009, 07:47 PM | #5 |
67-72 parts collector,…
Re: 78 brakes
If you have been pumping the pedal with the hose off you have air in the lines.
Start over. Make sure all hoses and lines are clear. Front hoses could be collapsed. Now's a good time to replace them anyway. Reconnect all lines. Bench bleed the master cylinder. "Pump up" the pedal and then crack the caliper bleeder, while someone has their foot on the pedal. It may take many tries to get the air out. Any time you release the pedal with the system open,... you will draw air back into the system.
11-13-2009, 09:08 PM | #6 | |
Happy to be here
Re: 78 brakes
I trick a I learned a long time ago is use a piece of vacuum hose on your bleeder. First loosen it a bit, then put your wrench on, followed by a piece of hose. Run the hose to a full bottle of fluid and submerge the end. Have a helper pump and hold while you open the bleeder. Close and repeat. This prevents fluid from going everywhere, and eliminates the possibility that air will be sucked back in the system.
11-14-2009, 09:34 AM | #7 |
Re: 78 brakes
so what happen to the porp valve? how does it shut of fuild ? can it be reset?
11-14-2009, 03:13 PM | #8 |
Re: 78 brakes
Get one of these and then you dont need someone to pump the pedal....
http://www.brakebleeder.com/index.ph...products_id=16
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
11-14-2009, 06:14 PM | #9 |
Re: 78 brakes
ok i bench bleed the M/C i still have no fuild to either side of the calipers im stumped?????
oh by the way ive always bleed the brakes on anything ive owned by pumping the pedal , then holding the pedal ,cracking the line and pushing the pedal to the floor then tightening rhe bleeder and do it all again a few times Last edited by 78-5.3; 11-14-2009 at 06:27 PM. |
