Old 11-14-2009, 12:29 AM   #1
bluesfella
bluesfella's Avatar
Unhappy Another dumb question - how to remove instrument cluster?
It's hard to see what I'm doing up in there...I'm trying to remove the cluster without damaging it. Do I need a special tool to remove each knob first, or can I pull it out as one unit?
Thanks!
www.vancerutherford.com
bluesfella is offline   Reply With Quote
Old 11-14-2009, 01:20 AM   #2
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Re: Another dumb question - how to remove instrument cluster?
You have to remove the knobs. One of them, I think it's the choke, has a piece of metal from the dash that the assembly goes through. I just used needle nosed pliers to undo the nuts on each switch.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 11-14-2009, 10:40 AM   #3
ChevySixty6
ChevySixty6's Avatar
Don't forget the headllight switch has that button to push in on the side of the switch that you push in as you are pulling the knob and shaft out. You'll have to reach up under the dash to get to it. I then use a BIG washer to fit in the slot to unscrew the retainer on the front of the dash that is holding the switch to it.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 11-14-2009, 12:26 PM   #4
Woogeroo
You did not say what year your truck is... but this should help.
-W
Installing a Tach in a '64-66 Chevy Truck
some pictures of my '65 c10 cluster taken apart
Woogeroo is offline   Reply With Quote
Old 11-14-2009, 07:43 PM   #5
bluesfella
bluesfella's Avatar
That helps alot, guys. Thanks!!
And Woogeroo, mine is a '66, so those links were right on.
