62 on a 68 frame???
good morning, I have a quick question, would there be a lot of fabrication to put a 62 on a 68 frame ? thanks guys i'm still trying to piece together a project.
I searched the site but didn't quite find what I has looking for. |
#2 | |
Re: 62 on a 68 frame???
#3 | |
One day...
Unless your planning on modifying a ton with a frame, why not buy one a couple years older and just bolt everything on..? Just curious that's all.
no problem, i'm working with what I can find locally, and the price was too good to pass up, and I don't have a cab yet. I am thinking about pick up the 62 cab, clip, and bed. anyway and holding on to it
I guess i should change to the 67-72 thread,
One day...
Na if you still have a 62 cab it doesnt matter what thread now
![]() Thats cool i guess if the price was right anything can be done ![]() |
I looked for a 6x-66 frame & bought one. Turned out it was tweaked from heat or something.... I had already done some modifications on a 68 lwb frame that worked better than anticipated..... So, I took that frame, cut it down to a swb, & used it for my 64's project chassis.
