Still plays with trucks
Re: Bummed Out!
There are a couple shorter bolts on each end under the valve cover area that can be covered with oil and can easily be out of sight.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
No Nonsense
![]() Join Date: Sep 2009
Re: Bummed Out!
Only saw these on the pad on the front passenger side of block
VO2 19UA Thanks for your time 68TT
Bi-Centennial Blazer ![]() ![]() Last edited by Libertad; 11-18-2009 at 11:11 AM. |
#3 | |
Re: Bummed Out!
They can be stuck on there pretty good. I had to use a long pry bar to break mine loose after 30 years on the engine. I was afraid I was going to break the head casting I had to pry so hard. With only two letters at the end of the code shows it is a 1969 & earlier block. 1970 & newer had three letter codes. Make sure there isn't one more letter there. All the UA_ three letter code engines are 1981 vintage 305's that came in half ton trucks. A UA code small block is a 1969 truck 200 hp 2-bolt main 307 cubic inch motor. Put a tape measure on the cylinder bore and let me know what it shows. A 307 has a 3-7/8" bore so it should be obvious that it is not a 4.00" bore like a 350 or 327. A 305 is just under 3-3/4" bore. Either UA code engine is not worth the effort to rebuild it when damaged.
#4 | |
No Nonsense
Re: Bummed Out!
Bi-Centennial Blazer ![]() ![]() Last edited by Libertad; 11-18-2009 at 11:16 AM. |
No Nonsense
Re: Bummed Out!
Ok another question I have 882 heads are these heads any good? I may want to put them onto a 350 short block when I find one.
Bi-Centennial Blazer ![]() ![]() |
#6 | |
Re: Bummed Out!
Low compression with flat to pistons and they are unleaded compatible unlike the heads that came on that 307.
#7 | |
No Nonsense
Re: Bummed Out!
#8 | |
No Nonsense
Re: Bummed Out!
I may buy one of these 350 blocks
any thoughts?
Bi-Centennial Blazer ![]() ![]() Last edited by Libertad; 11-17-2009 at 12:44 PM. |
Re: Bummed Out!
Depends on what you want to do with the truck.
What kind of power are you looking to build?
No Nonsense
Re: Bummed Out!
reliable daily driver with mild cam
