Old 11-18-2009, 07:38 PM   #1
buildinga55
Rear end and wheel backspace help
My truck is apart right now as I am doing bodywork. But would like to start wheel shopping. My truck has a 10 bolt rearend that the best I can tell is about 61-62" wide. I am not tubbing or anything but would like to know what backspace and width of wheel would work on the rear of the truck. I am thinking of using 17 or 18" wheels on the rear. What have you guys found works well? Thanks
buildinga55 is offline   Reply With Quote
Old 11-18-2009, 07:53 PM   #2
50adrod
50adrod's Avatar
Re: Rear end and wheel backspace help
mine is 60 inches and I have 4.5 backspacing and that is the limit they barely cear
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 11-18-2009, 07:55 PM   #3
buildinga55
I will have to take the wheels off to get an accurate width, but is a help. Thanks
Old 11-18-2009, 08:00 PM   #4
buildinga55
How wide are your wheels and what is the tire size? Is the tire clearance close to the fender as well as the bed?
Old 11-18-2009, 08:23 PM   #5
buildinga55
Found your build thread, nice work. I see you went with the wider fenders so the tire size is not important. I am going with stock fenders so maybe someone has some wheel and tire sizes. Thanks for your help.
Old 11-18-2009, 08:24 PM   #6
50adrod
50adrod's Avatar
my rear fenders are 2 inch wider than stock but I have, 17x10 with 315/35/17's rear and 17x8 with 285/17's front
Old 11-18-2009, 08:26 PM   #7
50adrod
50adrod's Avatar
thanks, guess our post crossed but that should give you some idea, mine is almost to close for comfort so 4 1/2 would be a good backspace for you to start with.
Old 11-18-2009, 08:55 PM   #8
buildinga55
Do you think I could go with a wheel wider than 8" with a stock rear fender?
Old 11-19-2009, 10:20 PM   #9
Atomsplitter
Atomsplitter's Avatar
55. My rear end is the same width as yours and I'm using zero offset 15x8Corvette Rallys. My 245/70R15's are about 1/2" from touching my stock rear fenders.
Atomsplitter is offline   Reply With Quote
rear end backspace
