Old 11-18-2009, 07:01 PM   #1
creamsicle68
wiring harness matchup!
hey guys. i got a new wireing harness out of a junk truck and wired up the engine bay, but the truck i got the motor harness out of the under dash was all cut up and junk. there is a saburban right next to it that has a good dash and good under dash harness but it is a tbi model and my truck is a carbed model. so my question is will the harness for under the dash be the same for both trucks or do i need to fine one out of a truck like what i have? my truck also has the power windows and stuff so idk if that effects anything.
thanks, Dalton
creamsicle68 is offline   Reply With Quote
Old 11-18-2009, 11:13 PM   #2
sailed2japan
Jonny
sailed2japan's Avatar
Re: wireing harness matchup!
You can uae the harness from the TBI truck, you just have to cap off the wires for the ecm and fuel pump. I suggest keeping them installed incase you decide to use them for an add on in the future. Any fuse block should have a place to plug in your windows and locks. My truck came without them and i just installed a factory set up and it plugged in and worked fine.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-19-2009, 07:38 AM   #3
creamsicle68
Re: wiring harness matchup!
alright awsome. Thanks
Old 11-19-2009, 08:28 PM   #4
sailed2japan
Jonny
I mentioned before to cap the wires, but pulling the fuses will yeild the same result. the point is to not have live wires floating around
-AEC Hundley USNR
