11-19-2009, 06:24 PM | #1 |
Ball Joint Dust Boots? where to get them..
i've looked everywhere for them and i can't find anyone that sells the replacement boots without the entire ball joint. i'm in the process of putting my lowering spindles on and found a couple tears in the lower boots, so i figured now is the time to replace them.... The ball joints themselves are not that old, and besides i don't have the extra $$ at the moment to buy new ball joints that run like $40 a piece...
I know drop spindles are very common, so there has to be someone who has run into this problem before
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
11-19-2009, 06:40 PM | #2 |
Dually Pride
Re: Ball Joint Dust Boots? where to get them..
dust boots? we don't need no stinkin' dust boots! you try NAPA? what about a cheepie place like VIP?
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
11-19-2009, 07:01 PM | #3 |
idk what VIP is, but yes i did try NAPA, and they said try Groth Bros, and they said i might be S.O.L
11-19-2009, 07:57 PM | #4 |
Dually Pride
VIP might be regional....duh moment
yeah I'm thinking you're S.O.L. once the boot gets compressed there isn't much that can get past the tears, put the grease to 'em and call it good
11-19-2009, 08:02 PM | #5 |
Jonny
Buy a new pair of ball joints from autozone keep the dust boots and return the ball joints. The idiots they have behind the counter won't notice. It may be wrong, but so is selling crap parts.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
11-19-2009, 08:05 PM | #6 | |
my only other idea was to take the boots off, clean the out side surface, and fill the cracks with some sealant. i have no idea if it'll work, but i guess it's better than nothing...
11-19-2009, 08:41 PM | #7 |
11-19-2009, 09:01 PM | #8 | |
Someone has taken this apart with a "pickle-fork" some time in it's life....which is fine, if you are replacing the ball-joints, not so much if you are just taking it apart to replace springs or spindles.
Everybody step away from the pickle-fork.....it bites.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. Last edited by LONGHAIR; 11-19-2009 at 09:01 PM. |
11-19-2009, 09:16 PM | #9 |
Jonny
Insted use a pry bar between the spindle and a-arm put preasure on it and hammer on the side of the spindle where the bolt joint stud goes through. a few solid hits and the vibration should pop it free. If not, get a bigger hammer.
11-19-2009, 09:52 PM | #10 |
18 Till I Die
I am pretty sure you can get new ones at Energy Suspension...I think I bought Tie-rod boots. They come in red or yellow..Not sure about black?
Yup here Ya go http://www.energysuspension.com/prod...int-Boots.html
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... Last edited by kelsfine69; 11-19-2009 at 09:53 PM. |
11-19-2009, 10:39 PM | #11 |
^^^ Energy Suspension to the rescue again. I just used their greasable poly kit for the front swaybar on my K5. Fit nice and really helps the ride after the lift. I tried pressing new eyelet bushing in from NAPA without luck, and the fronts they sell are too small ID for a 4x4. (1.25" is what is needed)
Dunno how tuff they will be trying to use the ORD quick release mod thou. Might negate the 'quick' part.
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
11-19-2009, 11:22 PM | #12 |
86 C10
Every parts store should sell them you just have to go to there "help" section its not going to be on there computer system so dont ask them or ask them where the "help" section is at and look there.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
11-20-2009, 12:22 AM | #13 |
what's the "help" section? and how do i know where to find it?
11-20-2009, 12:24 AM | #14 | |
11-20-2009, 12:39 AM | #15 |
have you tried to match up the universal dust boots they have at napa just match up the shaft diameter
11-20-2009, 12:42 AM | #16 |
i did, it was way off from the boots they had
