11-17-2009, 01:20 PM | #1 |
Adding Power Locks and Windows
If i want to add power locks and windows to my '78 K10, am I OK just buying the kits from LMC Truck, or should I try to find factory parts from a different vehicle for added strength and durability?
If your answer is the 2nd one, where do I start looking? How much would I expect to pay? (The kit on LMC is $90 for the doors, $170 for the windows) thanks. |
11-17-2009, 01:29 PM | #2 |
Re: Adding Power Locks and Windows
PM sent.
11-17-2009, 01:31 PM | #3 |
Project Optimus Prime
Im curious 2 know tha same info could u send me a PM 2 or just post tha info.
84 SWB work in progress 89 burb 1500 (parts pig) LOL 08 ford focus (I know, I know) Wifes car "I said it b4 and i'll say it agian wiring is my worst enemy":devil: |
11-18-2009, 01:25 PM | #4 |
ive seen alot of doors in the pick your part wrecking yards out there for 35.00 and up each door, the good thing about a pick n pull is you can pull the power door harness out of the truck you get the doors out of..
11-18-2009, 01:46 PM | #5 |
yes please post the info rather than pm.....i wanna know too
76 Chevy Fleetside 63 Lincoln Continental w/ Ford Racing 460 (550hp) 2012 VW GTI 2013 Escalade 2008 Harley |
11-18-2009, 10:59 PM | #6 |
I'm in the middle of swapping over to PW and PL's on my 86. I bought a complete cab from a wreck that had all the correct color interior door panels and complete wiring harness needed. You'll be hard pressed to drill the holes in the doors and door jambs w/out the doors being off the truck. The harness is installed but haven't had time to put the guts back into the doors yet. Even though the windows worked before removing they were slow. I plan on new motors for the window regulators. I also plan on cleaning and greasing the tracks and wheels on the regulators.
John
Locab36 1936 low cab 1/2 ton 1956 BMW R25/3 1968 Moto Guzzi V7 1969 BMW R100/2 1986 Silverado SWB 2007 Harley FLHTP 2011 GMC SWB 4x4 Z71 http://www.flickr.com/photos/locab36...7623329816080/ |
11-18-2009, 11:09 PM | #7 |
Jonny
I would suggest using oem parts from a junk yard. I just did this on mine and the harness went in easily. I put the whole doors on my truck so I didn't have to mess around installing the motors.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
11-20-2009, 06:00 PM | #8 |
I need some more help with this.
I cannot replace the whole doors because the truck has a new paint job, so that would be dumb to do. I need to either buy a kit from LMC or another aftermarket source, or go the junkyard/OEM route with a full rip and replace process. This goes for Locks AND Windows. Cost is not really a factor. I'll gladly pay a pro to do this, but I just want to give that pro the best kit right off the bat. |
11-20-2009, 07:32 PM | #9 |
Happy to be here
My suggestion is you find a donor vehicle. Look at Burbs as a good source as "most" of them came with PW & PDL. If you can snag the doors and "complete" harness your miles ahead.
Take the doors apart and get everything you need at one time. Install in your doors and enjoy.
11-21-2009, 07:22 AM | #10 |
And make sure the motors work before you put them in your truck.
11-21-2009, 11:05 AM | #11 | |
Still plays with trucks
I got the Suburban doors from a newer donor as well as the cross over harness but also found an older two door donor to get the wiring and driver side two window switch out of. I haven't had the time to do the swap yet but will document the process of the conversion, wire harness integration between the two styles of wiring and the 4-door to 2-door control wiring clean up.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
