11-21-2009, 10:49 AM | #1 |
Question....Firewall Insulation Fasteners
Dumb question, but is there a trick/technique/tool to install the firewall insulation retention fasteners? I have tried to put several in and have broken them all. I am not sure if there are other kinds, but what I have are the plastic barbed type.
11-21-2009, 12:48 PM | #2 |
Project Junkie! Fishing Poor!!
Re: Question....Firewall Insulation Fasteners
We have had the original style rubber fasteners reproduced. I never have liked the plastic ones that everyone else offers, because they brake so easy and if you need to pull them out they are done for. We also have most of the other firewall grommets reproduced, and we designed them to be better than original GM. Here is a link: http://www.classicheartbeat.com/rubb...atherstrip.htm
Check them out. You will not be dissapointed. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 11-21-2009 at 12:49 PM. |
11-21-2009, 11:56 PM | #3 |
The Older Generation
I made a tool once that worked pretty good. If you take a small bolt that fits in the hole in the fastener kind of loose (I think the one I had was about 4" long), put a nut on first, then a washer. Adjust the nut so that when the bolt is inserted into the fastener there is 1/8 to 3/16" between the head of the fastener and the washer. This will stretch the fastener a little before the washer pushes on the head of the fastener. If you can find a bolt that is threaded all the way to the head you can put a washer and nut on it first and thread it all the way up to give a bigger surface to push against. Or you can clamp a small pair of Vise Grips on the bolt at a 90º angle and push against them. LockDoc
11-22-2009, 11:18 AM | #4 |
PROJECT 7DEUCE
Seems like the rubber ones would be pretty forgiving to install.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
