Old 11-22-2009, 11:48 AM   #1
troykaz
Can you modify an EEC fuel tank to work in an older truck?
Hi all, I have a 71 3/4 ton GMC and I had to get rid of the fuel tank and sending unit. I picked up a good tank and sending unit out of a 72 chevy someone was parting out. Only problem is the new tank is an EEC tank with extra connections and the sending unit has 2 hoses instead of one. Can I cap off the extra nipples and use it this way or do I have to install a charcol canister and run the lines. Thanks in advance for any help.
troykaz is offline   Reply With Quote
Old 11-22-2009, 01:52 PM   #2
Re: Can you modify an EEC fuel tank to work in an older truck?
You can just plug the holes on the tank you don't need. No problems with the switch. I have a 72, ECC tank I used in my truck.
Old 11-22-2009, 04:58 PM   #3
troykaz
How would you plug off the extra fittings on the tank, would you use rubber plugs or something more permanent, like epoxy?
Old 11-22-2009, 06:28 PM   #4
I am using rubber (fuel safe) plugs.
