11-21-2009, 09:35 PM | #1 |
How hard/much to install a 67 front clip?
I have been looking to buy a k5/blazer/jimmy for a while now. Some of the trucks I have have the 67 front clip. To my eyes I really like it.
My question is how difficult and how much would this cost to do? If it only cost $500 in parts then I will just buy the nicer truck. If it turns out this modification cost thousands of dollars I will probably chose the truck with tired motor and 67 front end. Thanks for your input. |
11-21-2009, 09:54 PM | #2 |
Re: How hard/much to install a 67 front clip?
You can pick up a complete front clip off of a 67/68 truck for 300-800 dollars. The only thing you will need to install it is the 67/68 Rad support mounts. Other then that it is a bolt on set up as far as I have found.
11-21-2009, 11:55 PM | #3 |
Very easy to do in a weekend. Buy the better of the trucks then stick a 67-68 front clip on it.
Kevin LFD Inc. |
11-22-2009, 05:05 AM | #4 |
Thank you guys for clearing that up for me.
11-22-2009, 10:50 AM | #5 |
My question is what all parts need to be changed out?
11-22-2009, 10:56 AM | #6 |
fenders, grille, core support, hood.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-22-2009, 11:11 AM | #7 |
Is the front bumpers the same ? Thanks for a fast answer.
11-22-2009, 11:17 AM | #8 |
PROJECT 7DEUCE
The bumpers are the same i do believe up untill 71 when they moved the signal into the bumper. gmc bumpers are all the same except they have a small notch cut out on the top lip for the turn signals.. I could be off on this but if I am I am sure someone will correct me.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-22-2009, 01:17 PM | #9 |
406 Powered
Bumpers are same until 71. Lights are in bumper.
70 GMC 68 c10 2002 silverado 72 4x4 |
11-22-2009, 10:26 PM | #10 |
I am glad some else asked about all the parts. For some reason I thought it was just the grill, headlights, etc....
If you get all the parts for $800 (fenders, grill, hood, etc...). Won't it cost at least $1000 if not more to paint the fenders, hood, etc.... Sounds like a very easy swap but the true cost of the swap is probably around $1500 to $2000. |
