Old 11-20-2009, 11:39 PM   #1
jeffs67on22s
jeffs67on22s's Avatar
whats the cheapest but good way to drop the front of my 67 c10
i want to drop my truck so does anyone know a good way to drop the front end thats not to much money, ive already got the rear end done
jeffs67on22s is offline   Reply With Quote
Old 11-20-2009, 11:42 PM   #2
independentcustoms
Re: whats the cheapest but good way to drop the front of my 67 c10
How much you wanna drop it? You could cut a turn off a coil, that would be good for about 3 inches I believe. Or buy drop spring. After that you gotta buy spindles and springs. Or, you could Z the frame 3inches. That would be free if you do it yourself.
independentcustoms is offline   Reply With Quote
Old 11-21-2009, 12:34 AM   #3
OARNGESI
OARNGESI's Avatar
A 3 inch springs like 90 thru summit
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-21-2009, 12:36 AM   #4
mclairmo
cut one coil off
mclairmo is offline   Reply With Quote
Old 11-21-2009, 08:04 AM   #5
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Free is cheapest.
Here's my '71 with 1 1/4 coil cut off.
dropped about 3 inches.
I cut the springs with a grinder.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 11-21-2009, 11:05 AM   #6
Shane
Shane's Avatar
cut the coil spring with a cut-off tool ... NOT a torch ... procede to ride low
Shane is offline   Reply With Quote
Old 11-21-2009, 12:30 PM   #7
cdowns
cdowns's Avatar
yeah you can lower it for cheap why bother with replacing 40year old balljoints or tyrod ends or other old stuff while you're got it apart
Old 11-21-2009, 10:44 PM   #8
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
If you want your tires to wear right, use drop spindles. Cutting springs just messes up your camber.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-22-2009, 12:06 AM   #9
Shane
Shane's Avatar
Cutting springs does not mess up camber any more than dropped springs do.
Get your front-end aligned afterward and you'll be fine.
Old 11-23-2009, 01:20 AM   #10
unclewatts
unclewatts's Avatar
That's true, but either cutting or buying drop springs messes up your camber unless you DO get an alignment. That's all I was saying. I might add that shortening the springs by either method reduces vertical wheel travel whereas using drop spindles does not which makes them preferable.
Old 11-23-2009, 07:23 AM   #11
jim zag
ENGINE BUILDER
jim zag's Avatar
I cut one and a half coils off the front springs on my truck and it rides on the snubbers. You should at least check your toe in. I bought some circle track toe in plates off EBAY they work great and they are cheap! My pal bought a caster camber gauge from Speedway Motors and I set my camber to zero or slightly negative and then adjusted the caster to make the truck drive straight with no hands on the steering wheel. WORKS GREAT!
JIM ZAG
jim zag is offline   Reply With Quote
Old 11-23-2009, 09:51 AM   #12
Shane
Shane's Avatar
Shorter springs has nothing to do with wheel travel either. <sigh>
Old 11-23-2009, 04:18 PM   #13
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Really tell me how that works??..I can understand drop spindles and that statement but short springs = less travel.....
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 11-23-2009, 04:28 PM   #14
Shane
Shane's Avatar
Shorter springs only locate the spindle further UP the arc of a-arm travel.
The spindle can still move the same amount, it's just the "starting point" of the range of motion has moved.
Old 11-23-2009, 05:28 PM   #15
Hottrucks
Hottrucks's Avatar
ok but travel down may result is a lost spring......I have heard of guy having springs pop out of the pocket if they cut to much off
Old 11-23-2009, 06:01 PM   #16
Shane
Shane's Avatar
You will not lose a spring if only a single round is cut. I promise.
