Old 11-23-2009, 08:59 PM   #4
jaycrew1
jaycrew1's Avatar
Re: Windshield Wiper problems
Success,,, sort of.
I followed the diagram sent by 87bob. I ran a ground from the #2 terminal on the motor. Now high and low are working, however the motor will not shut off at all until the ignition key is turned off. The motor runs on low through the whole delay portion on the switch and on low speed, then high on high speed portion of the switch.
I appreciate the help. Did the 85 have delay wipers? Was the switch in the dash or on the column? I not sure if the diagram will cross reference to my truck. Just curious. Thanks again for your help.
jaycrew1 is offline   Reply With Quote
