Old 11-22-2009, 04:11 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
front end in a '78 camper special?
i'm thinking about doing some crossover steering when i get home, and i'm trying to figure out weather or not i need new knuckles....
i think i have a 44 up there, but i can't remember how many bolts are on the cover. can somebody help me out here?
i know that there is a 14 on the rear, 454 th400...
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 11-22-2009, 04:22 PM   #2
oats84
oats84's Avatar
Re: front end in a '78 camper special?
If i remember right there should be ten bolts. and if you have a right side knuckle that has a flat top you can have it machined for the studs. I you don't you will need new knuckles. I have a matched set extra sitting in the shed.There used to be a axle id chart on coloradok5.com in the spec section .
1989 jimmy "U.A.V"
44/14blt 4.56s locked up
37's
1984 2wd swb
1969 swb 4x4
oats84 is offline   Reply With Quote
Old 11-22-2009, 05:06 PM   #3
2tons of fun
you will need new knuckles, the flat top pside was only used till 75.
being a 78 it should be a 10b axle but it could be a d44, doesnt matter.
you will need both knuckles because the tierod enter from the top on 75 and ealeir knuckles. but you will only need to swap the knuckles, EVERYTHING ELSE WILL WORK !!!!!!!
2tons of fun is offline   Reply With Quote
Old 11-22-2009, 05:07 PM   #4
b454rat
Think your truck might be too new to have flattops. Might even have a 10 bolt and not the Dana 44, but you could get a 44 up to 80, so anything is possible.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 11-24-2009, 03:35 AM   #5
2tons of fun
there is no might about it, they stopped useing flat tops in 76. 75 was the last year, period.
if you brothers aunts cousin has a 84 with a d44 and flat tops it because some one put that axle in the truck.
Old 11-24-2009, 06:10 AM   #6
84 400
Sb 400 club
84 400's Avatar
Most likely a 10 bolt. They made the switch in 1977. Course they could of used a 44 but unlikely. Way to tell is if the diff chunk has "ears" on the bottom. If so its a ten bolt. For the cross over you will need flat top knuckles out of a Dana 44 pre75 i think. I would checkk on CK5 or wheeling dixie or one of the other 4x4 boards part section. Heck you can even try on here maybe pirate4x4...
here is a pic of the ears on the bottom ten bolt
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
