Old 11-23-2009, 09:36 PM   #1
badassciviv
badassciviv's Avatar
lift kit for 68?????
quick question, i found a lift kit (front lift springs with rear blocks) that fit 69-72. What is the difference between a 68 to 69 frame? will this kit not work?
[B][/B]
James
68 GMC SHORT FLEET 4x4
83 Dodge short fleet 2x4
2000 Civic SI
badassciviv is offline   Reply With Quote
Old 11-23-2009, 10:22 PM   #2
vectorit
What?
vectorit's Avatar
Re: lift kit for 68?????
The 67-68's have shorter springs IRC.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-23-2009, 10:54 PM   #3
badassciviv
so would that mean that both the front and the rear leaf spring length will be different from 67-68 from the 69-72 set up or is it just the rears that are differnt lengths?
[B][/B]
James
2000 Civic SI
Old 11-23-2009, 10:56 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
I "think" it is the fronts that are different. The widths may be differnt also.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-24-2009, 08:32 AM   #5
eric67m
eric67m's Avatar
Are you talking 4x4's with leaf springs front and rear?
I am not sure about lengths but as far as widths go......
I believe that the fronts are all 3" wide at the frame hangers on each end and 2.5" at the axle.
Rears are where 67&68's are different. They are like the fronts 3/2.5/3. The rears on 69-72's are straight 2.5".
Right now I have both a 1967 and a 1972 chevy k10 frames in my driveway (doing a swap). I imagine if you wanted to be able to find lift kits easier you could use the rear spring and perches from a 69-72 on an older frame. Frame swaps get silly really quick, trust me!
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 11-25-2009, 03:18 AM   #6
badassciviv
I am talking about 4x4 with leafs on the front and back. the Rears have a tapered spring on the 68? is it hard to change the spring perches to a 69
spring set up? Good luck with your swap thanks for any info you can give me
[B][/B]
James
2000 Civic SI
Old 11-25-2009, 08:25 AM   #7
eric67m
eric67m's Avatar
I have not looked really closely at the rears but I imagine you could take off the rivets that hold on the old brackets (grinder, drill, chisel, torch) and bolt on the new ones. I just am not positive if the placement is exactly the same. Before I got my newer frame I was talking to livrat about buying newer perches off of trucks that he was parting, so Im assuming it is R&R.
Old 11-25-2009, 04:55 PM   #8
Mxracer202
Mxracer202's Avatar
haha glad i found this first. I was planning on getting a 6" lift for my 67 c10, 1/2 4x4. the kits say 69-72 but i just figured it was a small difference.
badassciviv keep us posted on what you do.
58 Jeep willys pickup
67 K10 4x4- soon to be trail truck
TROUBLE MAKER RACING
"If you can't stand BEHIND our troops, please stand in FRONT of them."
Mxracer202 is offline   Reply With Quote
Old 11-25-2009, 06:08 PM   #9
Mxracer202
Mxracer202's Avatar
ok this is what i got.
Front
44" long bolt to bolt.
4"-2 1/2"-4" wide
Rear
56" long bolt to bolt
4"-2 1/2"-4"
dont know if this helps any
NOTE: this is for my 67 c10 4x4
Old 11-25-2009, 07:29 PM   #10
badassciviv
THIS IS WHAT I HAVE....
front spring length 44" bolt to bolt 3" at the front hanger 2.5" at the axel 3.5" at the rear axel, 3 leafs
Rear spring 57" bolt to bolt 3.25" front hanger. 2.5" at the axel 3.25" rear hanger 2 leafs
What do you 69-72 guys have? lets get to the bottom of this, us 67-68 guys want to jack our trucks up!!!!
[B][/B]
James
2000 Civic SI
Old 11-25-2009, 07:48 PM   #11
badassciviv
ok I found a site that has the specs for our springs
http://www.generalspringkc.com/index...parent=13&pg=1
says the fronts are the same
does not list the rears for 68 or 67 but it looks like the measurements I took look to be the same length and width at the hanger. I guess all we need to find out is the width at the axel.
[B][/B]
James
2000 Civic SI
Old 11-25-2009, 10:09 PM   #12
msgross
msgross's Avatar
I'm pretty sure that 69-72 use shorter rear springs that 67-68.
Your best bet would be to do a rear shackle flip and new front springs for 4". I remember looking for my truck as well and no shop knew the difference.. search on the forum for some details since I know this comes up about once a year.
I did slightly longer front shackles with an add-a-leaf in the back. Very mild but I gained 1.5" and run 33" narrow tires
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-19-2011, 09:53 PM   #13
Chevybowtie
Chevybowtie's Avatar
I got a 6 inch tuff country ez-ride on my 68 k10, and all i did was did the front how your suppose to do it. In the rear i have 5 inch blocks and put add a leafs on the stock springs, worked just fine. The difference is that the 67-68 rear leafs were 56" and 69-72 are 54", or thats what i've heard. Hope this helps.
1968 Chevy K10 56,000 miles
Chevybowtie is offline   Reply With Quote
Old 09-21-2011, 11:48 AM   #14
67gmcstepside
So, for 67/68 the 69 leafs will work in the front but the issue is the back?
67gmcstepside is offline   Reply With Quote
Old 09-21-2011, 04:24 PM   #15
bfay17
Young Gun
bfay17's Avatar
I believe you could also use some kind of spacer between the newer springs and the old hangers. The trucks had either 52" or 56" springs and the 56" are an option from most lift companies. You can get 56" springs and make up some spacers to fit between the hanger and leaf eye on both sides I wouldn't think it would be a problem doing this but others may chime in to.
1968 chevy c10 soon to have 454 and turbo 4006
1970 custom/20 4x4 454/sm465/np205 around 7 inches of lift with 36's.
1992 2wd sierra 5.7 with edelbrock intake, headers, and a Chip. Posi rear with 235/75/15 tires.
Soon to have a few more upgrades
2003 ccsb 1500hd
bfay17 is offline   Reply With Quote
Old 09-21-2011, 09:41 PM   #16
Mt Man Chad
Mt Man Chad's Avatar
I want some 33's on my 68 burb and need a little clearance.
flip kit link - http://www.sky-manufacturing.com/new...duct.php?id=98
Ordered the flip kit today, I'll let ya know how they work in the rear.
So for the front this type setup should work except shocks.
http://www.roughcountry.com/chevy_4wd_73-76_4.html
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 09-30-2011, 08:49 AM   #17
Chevybowtie
Mt Man Chad I would go with 2-4 inch depending how much clearance.
Old 10-04-2011, 11:50 AM   #18
hereinmissoula
very interested in knowing how the sky shackle flip went....
hereinmissoula is offline   Reply With Quote
Old 10-05-2011, 10:49 AM   #19
67gmcstepside
I just ordered a skyjacker 2.5 lift, front leafs and rear blocks. I'll see how it rides and decide if I flip.
Old 10-06-2011, 10:56 AM   #20
Mt Man Chad
The flip's arrived but have not been home to put them on.
I post some pics when complete.
