Old 11-25-2009, 02:22 AM   #1
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Tell me what you think
I really wanted a cowl hood for my Longhorn but I couldn't see spending the money right now since the truck does not run. So I put a hood scoop I had laying around on my hood. I'll have to put better primer on it later, and this is only with one light coat of filler. Tell me what you think.
Ryan
1969 Chevy milk truck
Old 11-25-2009, 02:28 AM   #2
OARNGESI
OARNGESI's Avatar
Re: Tell me what you think
Looks really good im just not a big fan of the cowl hoods
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-25-2009, 02:29 AM   #3
EA69TRK
EA69TRK's Avatar
wow that looks better than most of the aftemarket ones i have seen how big of a cowl is it?
EA69TRK is offline   Reply With Quote
Old 11-25-2009, 02:30 AM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
What was your procedure for doing this?? I did this once with a hood on my old 72' 4x4 with a 3-4" fiberglass scoop. We riveted it to the existing hood and fiberglassed and bondo it, but it wound up cracking not to long after. Not much you can do when the hood vibrates as bad as these old hoods do. You can use the new adhesives that they make for fiberglass bonding which I hear great things about, but I don't think there will ever be a way to keep it from cracking around the edges. You are doing a good job, and I don't mean to be a debby downer, just sharing my luck. That and the overhang of your hood scoop, might interfere with opening the hood as it might hit the windshield when opening, but not sure. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-25-2009, 02:45 AM   #5
Dieselwrencher
Thanks guys. Trevor, I thought about that and I guess I will cut it if needed. I used a valvoline brand 2 part epoxy/glue. I have used this stuff before and I love it. It works on bare metal, aluminum, and smc/fiberglass, and even bond metals to some wood. I used this on the firewall of my corvette and I know it sees lots of vibrations due to the basically solid engine mounts , the diesel, and the drag racing. No cracks anywhere where I used it. I used this on the front clip when I built it as well. This stuff works great. I have used another brand in the past and it liked to crack a lot. It was Lord Fuser brand.
Ryan
Old 11-25-2009, 02:53 AM   #6
Dieselwrencher
I think it is a 2 1/4" scoop. I will describe the process I did so you have an idea. I used 80 grit and sanded the area where the scoop will be. I primered this area. I put the scoop on the hood and trimmed the front to go over the rib of the hood. I then eye balled the scoop on the center of the hood because I couldn't measure this one because it was on a hood once before. Then I used 80 grit and cleaned the surface of the scoop. I reinstalled it on the hood, used self tapping screws and mounted the scoop. I marked the edges as well as the inner lip at the opening at the rear of the hood. I removed the scoop and sanded to bare metal with 80 grit again. I cleaned it all and then applied the epoxy on the scoop first. I laid the scoop on the hood and then screwed it down. Then I epoxied all the way around the scoop. I then used masking tape and put over the epoxied area to smooth it out. I let it set over night and then removed the tape and screws. I epoxied the screw holes shut and let them dry. Then I took a sanding block with 80 grit and sanded it to a contoured angle or smooth. I used bondo and beveled it back all the way around the scoop. I sanded it out with 80 grit and used spray bomb primer for now. I will have to go over the filler with a glazing putty when I put some real filler primer on it. I was happy with the way it turned out for my first real time doing this. The last time I attempted one of these I didn't get the scoop on correct because it too was used but I didn't notice the scoop was bent on one side causing it to be lob sided.
Ryan
Old 11-25-2009, 07:53 AM   #7
cdowns
cdowns's Avatar
looks good
Old 11-25-2009, 08:12 AM   #8
rustyescott
rustyescott's Avatar
i like this . can i copy the idea rusty
rustyescott is offline   Reply With Quote
Old 11-25-2009, 08:33 AM   #9
68_Step
I like it, I have always been a fan of cowl hoods on older trucks.
68_Step is offline   Reply With Quote
Old 11-25-2009, 08:35 AM   #10
jholley
jholley's Avatar
Looks good, nice work.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 11-25-2009, 08:45 AM   #11
rsavage
rsavage's Avatar
I think it looks great. Nice job.
rsavage is offline   Reply With Quote
Old 11-25-2009, 04:45 PM   #12
Dieselwrencher
Thanks. Go ahead and give it a try. Body shops do this all the time. I used to work in one when I went to college and this was common practice for this. I know it works better than fiberglassing one on. I've done that and it is a lot more work for sure getting the scoop to feather into the hood.
Ryan
Old 11-25-2009, 05:45 PM   #13
bigguy69
dazed and confused
bigguy69's Avatar
looks good!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 11-25-2009, 09:20 PM   #14
brn agn
brn agn's Avatar
I think it looks good. It reminds me of the shape of the 69 Z28 hoods.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 11-25-2009, 09:26 PM   #15
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That looks damn good..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-25-2009, 09:41 PM   #16
flashed
That looks good , I want one too someday.
flashed is offline   Reply With Quote
Old 11-26-2009, 12:34 AM   #17
Smallz72project
Smallz72project's Avatar
Hood turned out really well, props for that. Used to work in a body shop myself, and now because of it...Im super anal about body work. Sometimes I think Im too anal about it. Love how the line matches up and blends in the middle. One thing I do notice....needs a bit more massaging/blending on the sides..at least on the left side. I can see the out line of the cowl through the primer and will only become more apparent with paint. But other wise superb job!! Is it, or will it become functional, or just aesthetics?
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 11-26-2009, 12:39 AM   #18
LockDoc
The Older Generation
LockDoc's Avatar
Looks great!
Let me know when you are ready to do another one...
LockDoc
Leon
Old 11-26-2009, 02:47 AM   #19
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Great fab work there! Not to be a buzzkill or anything, but have you test fit the hood. It looks like the cowl may come back far enough to contact the wiper cowl of your truck when raised.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 11-26-2009, 03:13 AM   #20
Dieselwrencher
I'm sure it would look better if it had real filler primer on it. This is with poof can Krylon primer. All my home tools are boxed up right now because we are putting up a new building. I'm sure it needs more work to be perfect, and I will finish it when I get it running. There some other bad spots on the hood itself I need to repair as well. And I doubt I will make it functional, that may change though.
Ryan
Old 11-26-2009, 03:15 AM   #21
Dieselwrencher
Thanks. No I haven't test fit it yet. I will cut it if needed once I get the hood on the truck. At the moment the whole front clip isn't on the truck so I couldn't test fit it. We shall see in a few days with any luck.
Ryan
Old 11-26-2009, 03:17 AM   #22
Dieselwrencher
Originally Posted by LockDoc View Post
Looks great!
LockDoc
Leon, we could set up a little work party sometime.
Ryan
Old 11-26-2009, 05:21 AM   #23
Lippyp
English Chevy Owner
Lippyp's Avatar
That looks great, I really want a cowl hood but the shipping to the UK is a real killer so this may be the only way to go for me. Does anyone produce a steel scoop that could be welded on?
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 11-26-2009, 11:15 AM   #24
71blksuper4x4
SWB 4x4 Collector
Here ya go LippyP,
http://www.thespeedcenter.net/SpeedC...meFrameSet.htm
TREVOR
Old 11-27-2009, 05:19 PM   #25
Dieselwrencher
I think those are cheaper than the summit ones too. The next one I do will more than likely be steel. Here are some pics of the hood on the truck. I don't have the hinges on yet because I was the only one around this morning. It's pretty hard to bolt one of these on by your self for sure. The rear part of the scoop is close, but it just might not hit the windshield when it opens up. I'll have to see later on.
Ryan
