Old 11-22-2009, 12:27 PM   #1
Restrorob
The One And Only !!!
Restrorob's Avatar
Truck Lowering Opinions Needed
Hey Guy's,
A club member has a 93 1500 short fleet he would like to drop, He likes the stance of my 97. Mine was dropped by the PO so all I know is it's a 4/6 with Bell Tech components.
I told him I'd do some gandering around and check here on the board.
This is what I've come up with since he's on a budget like most;
http://www.summitracing.com/parts/DJ...6/?image=large
http://www.summitracing.com/parts/DJ...2/?image=large
http://www.summitracing.com/parts/SU...2/?image=large
I tried the "Search" feature but that 60 second wait (different key words) has a lot to be desired.....
OK choice ?
Any problems with DJM components ?
Any better place to purchase ?
Thanks !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 11-22-2009, 12:33 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Truck Lowering Opinions Needed
You are right on target. I have had good luck with DJM products, as well as Summit Racing.
You might do better, if you consider Summit "white box" brand.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-22-2009, 07:28 PM   #3
Slow Build
Slow Build's Avatar
This was years ago ,but I had some problems with a spindle that was a factory flaw. DJM didn't give a damn. Didn't want to hear about it. Didn't want to see it. Nothing. I was on my own. A couple of years before that I had a problem with a BellTech spindle. They sent a new set and paid to have them installed. They also wanted the old set back. That's probably to protect themselves. I like a company that stand behind it products.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-22-2009, 08:24 PM   #4
Restrorob
Restrorob's Avatar
Thanks N2, The "white box" brand coil springs (Ground Force) were the same price as DJM's so just figured staying with the same brand. I didn't find the spindles or rear kit in the "white box", Did I miss them ?
Thanks SB for your past experience, I will take it into consideration. Did you buy your's from Summit ?
I have spent thousands with Summit without issues, I would hope as big as they are THEY would take care of any issues then take it up with their supplier ?
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 11-25-2009, 04:12 AM   #5
Slow Build
Slow Build's Avatar
Both of the spindles that I had problems with were on the trucks when I bought them. I bought my BellTech spindles that I replaced the DJM's with through ebay used. I did buy my Air Ride helper springs through Summit and was happy with that purchase.
Past GM Trucks:
