Old 11-26-2009, 09:24 AM   #1
78-5.3
78-5.3's Avatar
rear end gear replacment
how hard is it to replace the gears in a 12 bolts i wanna go 3.73 whats the process of replacing them??
78-5.3 is offline   Reply With Quote
Old 11-26-2009, 09:43 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: rear end gear replacment
If you have never done it, I would advise this is not the area to do for fun.
If its an open carrier, its really not that hard IF you have all the special tools.
But if you dont have a dial indicator to set the back lash, the orginal pinion shims to get the pinion depth close, (youll need a tool to set that), paste to check the ring gear pattern, inch pound torque wrench for the pinion pre-load check, and lots of patience, plus a press I wouldnt touch it......
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 11-26-2009, 10:45 AM   #3
nlped
nlped's Avatar
^^^ What he said. You can very easily screw up a set of gears if you don't know what your doing. It is a much better idea to just find someone who does this on the side and pay them to do it.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-26-2009, 11:11 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
3.73's in the truck 12-bolt are fairly common. You might be able to pick one up at the local pull it yourself junk yard for less than even the gear install kit costs. At mine it would cost me $85 for any truck / SUV rear axle assembly.
You can also just get the ring & pinion / carrier assembly if you have the tools to get it out for about $27 or hit the main yard and have them get you one off the shelf for $42 if they have one that old.
With this the hardest part is setting the pinion preload when you are putting it back together. It really takes a dial indicator type inch-pound torque wrench to do it right. Not a common tool and not cheap. If you are not going to do this more than once you are better off financially to have a rear end shop replace the bearings and install the gears/carrier into your housing.
You could always go with the 88-98 new body style rear axle assembly that pushes the tires out closer to what the front track width is on the square body trucks. That rear tire inset vs. the front bugs me on our trucks.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 11-26-2009, 01:27 PM   #5
Cherub
Cherub's Avatar
Can you use a 90 91 suburban rear end. i thought they came with 3.73 or 3.42 with posi
Cherub is offline   Reply With Quote
Old 11-26-2009, 04:27 PM   #6
Lo78
if you put a rear in from newer truck dont you have to do some moving and welding to get things to line up?
Lo78 is offline   Reply With Quote
Old 11-26-2009, 04:41 PM   #7
3r!c84
Badass
3r!c84's Avatar
yes
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-26-2009, 07:37 PM   #8
78-5.3
78-5.3's Avatar
up here in MAINE there isnt any pull it yourself places thats what crappy about living in a salt belt LOL
Old 11-26-2009, 08:23 PM   #9
Matt Man
Matt Man's Avatar
that is one of the things i will never do on my truck i always let the pro do it because of the special tools you need.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-27-2009, 12:11 AM   #10
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Not all that hard a job, just time consuming and requires a few specialized tools. You must have a inch pound dial torque wrench and a dial indicator. Impact wrench helpful too. I found the hardest part was getting the old pinion races out.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 11-27-2009, 12:14 AM   #11
3r!c84
Badass
3r!c84's Avatar
but i did stay at a holiday inn last night
-00 Saturn 5spd
1/4:13:90
Old 11-27-2009, 09:42 AM   #12
68 TT
68 TT's Avatar
My old 91 Suburban had 3.08's with the 4L60 trans and it wasn't posi.
Old 11-27-2009, 10:01 AM   #13
68 TT
68 TT's Avatar
Yes you do, glock35ipsc just did it on his project Fred LS swap truck and explains what he did on about post #955.
http://67-72chevytrucks.com/vboard/s...t=fred&page=39
If you don't have the tools to do it then sticking with the truck 12-bolt is the best idea or maybe it is a good excuse to get a good 220-volt MIG welder and a cutting torch setup or plasma cutter.
