Old 11-27-2009, 05:05 PM   #1
dbmx66
is cutting 2 drop coils a bad idea?
i have 2 inch drop coils and 2.5 inch spindles, i want to go lower. would cutting the springs be bad?
thanks, david
dbmx66 is offline   Reply With Quote
Old 11-27-2009, 06:06 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: is cutting 2 drop coils a bad idea?
1/2 coil will get you approximately 1 inch of drop.
So cut carefully.
Keith
Convert to disc brakes.
Old 11-27-2009, 10:35 PM   #3
dbmx66
So cut carefully.
i was looking for 2 / 2.5 or wouldnt that work right?
do u have any pictures so i know what it should look like if i cut it properly?
thanks
Old 11-27-2009, 11:11 PM   #4
lolife99
lolife99's Avatar
thanks
Let me see if I understand you.
You have a set of 2" drop springs. Correct?
How much lower do you want them?
Cut a half coil. That will get you a 3" total drop.
I wouldn't cut more than a half coil.
Keith
Old 11-27-2009, 11:18 PM   #5
lolife99
lolife99's Avatar
Cut only the bottom of the spring.
(look at the red cut line)
Keith
Old 11-27-2009, 11:58 PM   #6
dbmx66
so where the spring stops, i cut the exact same spot on the other side of it? doi i cut the top or the bottom?
Old 11-28-2009, 12:25 AM   #7
SCOTI
SCOTI's Avatar
He answered you . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 11-28-2009, 12:29 AM   #8
dbmx66
sorry about that, im kinda bad with this. haha if you can tell.
will that mess up my camber?
Old 11-28-2009, 12:31 AM   #9
SCOTI
SCOTI's Avatar
You'll need to get the front re-aligned by someone that understands lowered vehicles. Shops that don't do 'dropped' vehicles will typically say it can't be aligned if it's dropped..... we all know they can. BTW.... more than 1/2 a coil off those shorter springs & they'll come loose anytime the front suspension is extended. They can (& possibly will) fall out if they come loose.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-28-2009, 12:33 AM   #10
lolife99
lolife99's Avatar
Edit:
Scoti,... you type faster than me.
Anytime you shorten the front springs, you will affect the camber.
I suggest getting the front end aligned when you are done.
I also suggest using a good quality drop shock.
Keith
Old 11-28-2009, 12:39 AM   #11
dbmx66
thanks guys, will i be fine if i only cut 1/2 coil off? or will it fall out?
i have brand new nitro drop 2 on already.
and by 1/2 coil u mean that after i make the cut, the piece i cut off will look like a "c" right?
thanks
Old 11-28-2009, 12:41 AM   #12
dbmx66
also, will it ride like crap if i cut 1/2 coil off?
Old 11-28-2009, 12:50 AM   #13
lolife99
lolife99's Avatar
It will ride the same as a 3" drop coil. Does it ride like crap now?
Full coil = O
1/2 coil = C
Post up some pics of your truck.
Keith
Old 11-28-2009, 12:52 AM   #14
lolife99
lolife99's Avatar
Can you take a picture of your front suspension already on the truck? (front the front side of the a-arm).
Keith
Old 11-28-2009, 12:53 AM   #15
lolife99
lolife99's Avatar
Spring might be a little loose in the spring pocket only when the truck is off the ground and the a-arm is hanging all the way down.
Keith
Old 11-28-2009, 12:54 AM   #16
lolife99
lolife99's Avatar
Do you still have the rubber bumpstops installed up front?
Keith
Old 11-28-2009, 12:55 AM   #17
lolife99
lolife99's Avatar
How tall of tire do you have up front?
Do you have room to drop it another inch and still have clearance at the fenderwell and the inner fender?
Keith
Old 11-28-2009, 12:56 AM   #18
dbmx66
Full coil = O
1/2 coil = C
last time i drove it had stock suspension. its been my project for a while now.
i dont have many good pics. they were takin months ago
heres one with 4.5/6 drop. how much will it drop when the motor/ front clip are on?
Old 11-28-2009, 12:57 AM   #19
SCOTI
SCOTI's Avatar
thanks
1/2 a coil off of 2" drop springs should yield about 3-4" of drop which put's you @ risk of them wanting to pop out of position if the front over extends. Yes, 1/2 a coil cut would resemble a 'C' vs. an 'O'.
That much spring drop is purely subjective; what's ok to one, may not be to another. I have never liked cutting more than 1-coil off of stock springs; I've never cut drop springs just because I didn't want to screw them up (I can re-sell an un-modified 2" drop spring to offset the cost of a new 3" drop spring).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-28-2009, 12:59 AM   #20
lolife99
lolife99's Avatar
OK.
Don't do anything until it's back together and on the road.
Keith
Old 11-28-2009, 01:05 AM   #21
dbmx66
OK.
do u know how much it will drop down the front after the motor and front clip are on?
Old 11-28-2009, 01:09 AM   #22
lolife99
lolife99's Avatar
no.
sorry.
I think you are getting the "cart before the horse".
Keith
Old 11-28-2009, 01:14 AM   #23
MrBeast
high-Tech Red Neck
MrBeast's Avatar
no.
sorry.
+1, you need to get your truck assembeled before you do because there are way too many variables that come into play. You go cutting your springs now you run a serious chance of cutting too much because they are not going to be fully loaded.
It isnt that hard to pull a spring once the truck is assembeled, save it for last, this way you are sure to achieve the look you want with out having to buy springs twice.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 11-28-2009, 01:15 AM   #24
dbmx66
that makes sense, thanks for the help.
i could always get it lower in the front with smaller tires couldnt i?
Old 11-28-2009, 01:22 AM   #25
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Smaller tires will bring the truck down, remember every 2 inches in diameter will bring the truck down 1 inch, if you are running metric tires you can use the calculator @ Discount tire's site.
