Old 11-26-2009, 01:46 AM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
2WD & 4x4 frame differences
Hey guys, not sure if I shoulda posted this in the 4x4 section or what, but here it is
Can someone explain to me the differences between 2WD & 4x4 frames... Particularly 67 frames
Thanks, Matt
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-26-2009, 08:28 AM   #2
eric67m
eric67m's Avatar
Re: 2WD & 4x4 frame differences
From what I have seen...
In the rear...
Most 2wd's are coil sprung rear, so the cross member and mounting points will be different. Coil springs have the cross member at the top for the spring and one in front of the axle for the suspension arms(track bar?).
4x4's are leaf sprung. Perches at each corner of the leafs (4 total).
In the front...
2wd's have a big, riveted in cross member which the A arms and coils attach to.
4x4's have spring perches in front under the radiator core support and shackles/mounts back just before the front cab mount.
The transmission cross member is different. 4x4 mounts between the transmission and transfer case.
I hope this helps. It is just what I know, definatly not everything. I know many people do conversions. Check the 4x4 board and also look in that section for different builds.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 11-26-2009, 11:34 AM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks, I pretty much knew all the common stuff
I just dont know if there are any real differences in the frames, or is it just the brackets & cross members
Sinister
Killer
Old 11-26-2009, 04:12 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Bumpity bump
Sinister
Killer
Old 11-26-2009, 04:23 PM   #5
OARNGESI
OARNGESI's Avatar
I think the front of the frame kicks up abit on a 4x4 about a inch and the rear wount curve out like on coil spring trucks atleast that how it seems on my blazer
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-27-2009, 10:36 AM   #6
That`s it,other than crossmembers.
Old 11-27-2009, 12:09 PM   #7
JimKshortstep4x4
The two wheel drive truck frames, (both coil and leaf spring) are wider at the kickup area over the rear end. The 2 wd frames are 38 1/2" wide and the 4 wd frames are 34 1/2" wide.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-27-2009, 03:01 PM   #8
sameyrasmea72
sameyrasmea72's Avatar
Some of the brackets and cross members are different for sure,but you could change some of that. The real difference as stated before is the frame rails themselves. A 2wd like in the pic goes up and out at the rear end. ( This is true even a a leaf 2wd) On a 4x4 frame the frame rails in this area are as straight as a board. I don't have a pic of a 4x4, but I will see if I can find one.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-27-2009, 05:13 PM   #9
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The portion of the frame where the steering box bolts on is a little different as well. You can see in this pic.
That is a steering box brace from a K5 blazer. It isn't off much, but it's still off. And the frame is a 72 3/4 ton Longhorn, so this may not apply to your frame.
Ryan
1969 Chevy milk truck
Old 11-27-2009, 05:30 PM   #10
greystoke
It would not be to difficult then to swap a 2wd truck and 4wd blazer like for like then? If a guy wanted to build a 2wd blazer that is.
greystoke is offline   Reply With Quote
Old 11-27-2009, 05:32 PM   #11
Dieselwrencher
I'm sure you could bolt in all the 2wd stuff in a 4wd frame. But I don't think I would do it.
Ryan
Old 11-27-2009, 05:36 PM   #12
greystoke
well...some would say not to cut a suburban down and build a four door but when all is said and done it makes for extreme coolness
Old 11-27-2009, 07:13 PM   #13
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks guys
I guess the search for a 4x4 frame is on
Sinister
Killer
Old 11-27-2009, 08:15 PM   #14
greystoke
what are you going to build spraybomb?
Old 11-27-2009, 08:23 PM   #15
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
My old 67 GMC long step Kilroy
I want him to be a 4x4 this time around
Sinister
Killer
Old 11-27-2009, 08:32 PM   #16
greystoke
love that, will be badazz. I really think i'm going to try that body swap. My dad has a 71 short, will be mine someday...later than sooner hopefully
Old 11-27-2009, 09:29 PM   #17
Dieselwrencher
I've seen guys put leaf springs on the coil spring 2wd frames. As a matter of fact Leon, Lockdoc, has a coil spring frame with leaf springs on it at his place. Maybe he could snap some pics for you. I'd just use your frame unless you can find a 4x4 frame easily.
Ryan
Old 11-27-2009, 09:52 PM   #18
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
I have a factory leaf sprung 1/2 ton 2wd frame. It has the same dimensions as my c10 coil sprung frame... If you want pics I can post some for ya.
screamin_c10 is offline   Reply With Quote
Old 11-27-2009, 10:39 PM   #19
OARNGESI
OARNGESI's Avatar
Originally Posted by greystoke View Post
it would not be to difficult then to swap a 2wd truck and 4wd blazer like for like then? If a guy wanted to build a 2wd blazer that is.
a short bed frame is longer than a blazer frame but you can add all 2wd stuff to a 4wd frame without too much difficulty
70 SWB STEPSIDE
70 BLAZER
09 challenger
