Old 11-29-2009, 03:25 PM   #1
TylerHuff
TylerHuff's Avatar
Re: low budget 79' Blazer build. 2wd
well i worked on the engine a little and tried to get that sorted out. the p.o. didnt put in a pcv valve so i did that and they had the brake booster hooked up to the front of the carb so i moved that and still need to get a fitting to hook it up.
I also worked on swapping out the front fenders got one on for now i ran out of sand paper so only got it partially body worked and rattlecanned it for now so i can finish it later. this weekend felt like i took more steps back than forward but sometimes it goes like that. i didnt get my rear wheels finished so hopefully i will get them swapped out tomorrow and have a full matching set on the truck
1987 Gmc sierra
1962 Apache 10
TylerHuff is offline   Reply With Quote
