good luck w/ it.....it's wasn't really too hard to actually put in.mine was a van column,so i had to lower the back-up/neutral safety switch 7" further down the column. i had to do some creative dremel work also to open up a slot in the outer column,and then again in the inner column for the tang of the back-up light switch to ride in.got some new rubber gaskets also,one for the firewall and one at the column metting the dash.fine69(board member),came thru w/ a intermediate shaft to link up the column's spline shaft to my rag joint.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
