Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 11-30-2009, 09:30 PM   #12
towb3
Re: maybe a v-8 swap need some info
Originally Posted by chevyndn View Post
make sure if you go tbi you use the right year of heads, cuz the four bolts in the middle are diiferent on older carb heads than on tbi, the older ones all angle, the 88-95 go stright up. you can use either heads if you woller out these four hole of the intake
If he is to order a new intake when he builds, they have intakes that can match up to what heads he is using instead of grinding up an intake.
towb3 is offline   Reply With Quote
