Old 11-30-2009, 12:54 PM   #1
Custom 68
Custom 68's Avatar
lower control arm shaft upgrades
Guys, I have my suspension apart swapping spindles. I am going to purchase some tubular upper a-arms to get some more caster. I cant afford the lower ones and am not sure I can or will gain much with them?
My question is there an upgrade for the control shaft on the lower? I have found some polyurethane parts but they are marked for 1973 up I assume these are different but not sure what all is?
When I grab the lower a-arm (still mounted) I can feel some movement front to rear at these connections not much but some. I rebuilt these before but think I may need to get new shafts. Any thoughts on this, is there something better I can do on a budget?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is online now   Reply With Quote
Old 12-01-2009, 10:22 AM   #2
Custom 68
Custom 68's Avatar
Re: lower control arm shaft upgrades
As expected the newer ones are press in and mine are the screw out type. I guess I will pick my best arms and get new control shafts. I think mine are somewhat worn, not much but some.
Dave
Dave
