Old 11-27-2009, 06:28 PM   #1
marcsRX
68 C10 SWB
marcsRX's Avatar
Van Tilt.
So after searching, this is the link people were posting.
http://67-72chevytrucks.com/vboard/s...=dremel+column
But its a dead link.
Does anyone have any info regarding doing a van tilt colum on my 72 C10???
I'd rather not spend $700 on a new column...
Thanx in advance for any and all help.
marcsRX is offline   Reply With Quote
Old 11-27-2009, 07:05 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Van Tilt.
See if you can find Kevin, Kevsclassics, he rebuilds them.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 11-27-2009, 11:42 PM   #3
Jurassic-1
Jurassic-1's Avatar
Thumbs up Re: Van Tilt.
You can use a van tilt if you modify a few parts. If you have an automatic it is necessary to relocate the neutral switch to the lower end on the column. If you are handy with taking the column apart you can recut the slot and move the switch. if you do not need a neutral switch it does not have to be moved. It will need to be removed so it will bolt up on a c10. Also the shaft at the bottom is longer and you can pull the shaft between the steering box and column and where it slides inside the shaft you should shorten the shaft about 2 inches this will allow movement in case of an accident. Do not try to do modifications if you are not sure how to safly do so. If that is the case purchase a truck column. It is cheaper than the hospital bills. Good Luck
Jurassic-1 is offline   Reply With Quote
Old 11-27-2009, 11:55 PM   #4
Boog
laying low
Boog's Avatar
Re: Van Tilt.
From the FAQ truck tech section.
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-28-2009, 12:05 AM   #5
OARNGESI
OARNGESI's Avatar
Re: Van Tilt.
I KINDA WANT TO TRY ONE PF THESE http://cgi.ebay.com/ebaymotors/STREE...Q5fAccessories
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-28-2009, 10:53 AM   #6
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: Van Tilt.
So any "van" column from a MY 67-72 will work. I dont care about the neutral switch.
So if i go to a junk yard and get a column form a chevy truck or van it will bolt in?
Originally Posted by OARNGESI View Post
That doesn't look half bad!
Old 11-28-2009, 11:38 AM   #7
sweet70beast
sweet70beast's Avatar
Re: Van Tilt.
My column came out of an 82 Van. Exact same as the ealier van columns.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 11-28-2009, 02:25 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Van Tilt.
Yes , Chevy van that had the key on the dash . Moving the switch is not that big of a deal . I have done this twice without dis assembly of the column .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-29-2009, 05:01 AM   #9
OhioDan
OhioDan's Avatar
I have a van column in my truck. I have heard, that the ones with the key in the column are larger diameter and won't fit? I have a 4 spd., so neutral safety switch was removed. Collapsed the intermediate shaft to get proper length, and bolted it in. Piece of cake.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-29-2009, 09:46 PM   #10
Stepsides 4Ever
Stepsides Are Bedder
Stepsides 4Ever's Avatar
Re: Van Tilt.
A little editing of the link does the trick. Try this:
http://www.67-72chevytrucks.com/vboa...ad.php?t=63328
Works for me!
Stepsides 4Ever is offline   Reply With Quote
Old 11-29-2009, 11:01 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Van Tilt.
I have never done one myself but I hear they slide right in with a few modifications.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-30-2009, 11:17 AM   #12
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: Van Tilt.
So to be clear, i can use a column out of a van up to 82 with the key on the dash right?
I can probably still get one at the salvage yard.
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
Old 11-30-2009, 12:31 PM   #13
hugger6933
Re: Van Tilt.
Yes, you can use the van colum. The years are fuzzy for my understanding, but it helps to look for round lights in the van. If the colum DOES NOT have a key switch it should work. I just bought a trilt from a chevy motor home [year unknown] and it is simmilar to the van tilt with the exception of the steering shaft being shorter where it hooks to the intermediate shaft. Jim
hugger6933 is offline   Reply With Quote
Old 11-30-2009, 08:48 PM   #14
sweet70beast
Re: Van Tilt.
I'm not sure when they went from round to square headlights, but the round will for sure have the right style column. Don't bypass the square headlights without looking because my 82 van had square headlights.
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 12-01-2009, 02:07 PM   #15
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: Van Tilt.
Even moar bettar!
Found a salvage yard with 72's on the lot! Going this weekend to pull er out!
