12-01-2009, 11:53 PM | #1 |
Tach swap question.
Just recently got a gauge cluster with tach from a 76. Wondering if (after taking guages apart and modifying) the tach will work on my 91 wiring (got from burban for tbi swap) for my truck, if i route all the tach wires to distributer and +, -? Read in Crossy guide that you cant due to speed sensor (VSS) feedback needed for computer. Wondering if someone made this work...
12-02-2009, 12:13 AM | #2 |
Re: Tach swap question.
so you have a 91 truck blazer burb?? and you want the tacho from a 76 to fit into the cluster and for the wiring to work??? i dont think it will im going a similar route 91 cluster with camaro tacho into my 78 truck the plug in the back is going to be the problem i think i have to cut into my cluster !!! i never went for a truck tacho coz of the 5000 rpm limit!!!
12-02-2009, 12:37 AM | #3 |
making the tacho fit and the small fuel gauge fit my 91 cluster on my 91 burban wiring, on my 86"TRUCK" is not the problem(put TBI with 91 burban wiring). I am asking if the Tach off a 76 cluster can be made to work on the TBI system stock distributer if i just hook it up to the distributer and +/-.
12-02-2009, 06:45 AM | #4 |
yes your 86 still has an HEI distributer.
1949 Five Window, 1973 Step Side, 2000 Z71 |
12-02-2009, 09:47 AM | #5 |
I took a cluster off a 79 and put it in my old 87, worked fine. I think your gonna have to rewire the gauges to get them to work, it's gonna be different and for the VSS speedo.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
12-02-2009, 11:41 AM | #6 |
Thx, hopefully everything goes great and il post results when i finish
