Old 12-02-2009, 10:01 PM   #1
kanuck
91 Jimmy front onto a 83
Just going to look at a 91 Jimmy front clip tonight. I think I would prefer the Blazer grille, but we'll see.
To do the conversion, do I need the newer rad support and is there a difference in Radiators? How about the wiring harness?
The clip is supposed to be in very good shape and I can get fenders, hood, grille and bumpers for $500 or a bit less. The owner was going to fix her up but found the floor rotted from the front to the back, so instead is going to use the frame and drive train to put under a 193?'s truck.
Is the dash or any other parts useable on my 83?
Will find out more tonight about what all is there.
Any pictures of trucks with the Jimmy front?
'70 Malibu with 383 stroker/T350
'56 SWB Mercury pickup..under construction
'67 Firebird Convertible...all done stock
'70 LWB 350 on propane...beater
'69 LWB 350/T400 body restored
kanuck is offline   Reply With Quote
Old 12-02-2009, 10:08 PM   #2
Jonboy
Slots go on anything!
Re: 91 Jimmy front onto a 83
You will need the radiator support, lights, grille and bezels, bumper filler, and wiring harness. The rest of the front sheetmetal and doors will work on your truck, as will the dash components (except the gauges).
Jonboy is offline   Reply With Quote
Old 12-03-2009, 12:09 AM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
You will have to splice the wiring harness into your harness. I have a 90 Blazer and the wiring harness plug at the firewall is different than my dad's 84 truck or our old 86 Blazer...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-03-2009, 12:21 AM   #4
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I did the Jimmy clip on my 86. As said above, you need the radiator support, grill, bezels, lights, filler panel for below the grill, and the harness. You can just cut the harness off back by the firewall on the Jimmy, and then splice it in to yours. A TIP I learned from doing mine: do not splice all the wires together at the same point, stagger them out some so they can still fit in the split loom easily. The swap is simple and straight forward. All of the bolts from the fender to the rad support will match so you don't need to track those too close. If you want more directions on how to I would be more than happy to type it all up. Just send me a PM.
Edit: Here is a picture
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 12-03-2009, 12:35 AM   #5
Driveway Dreams
I have car A.D.D.
And here is how you get there
-Gerald
Old 12-03-2009, 12:38 AM   #6
Driveway Dreams
I have car A.D.D.
Here is one more of the Jimmy clip set in place before the grill and bezels were put on. Hope this all helps any of you wanting to do the Suburban or Jimmy clip on a truck. Now you can see how it goes...sorta.
-Gerald
Old 12-03-2009, 02:10 AM   #7
kanuck
Well I went and looked at the 1991 Jimmy and came back confused.
The parts are in good condition but not what I expected.
The front grille is I guess from a base model and is painted silver and uses a single large rectangular headlight on each side with lower marker lights and in this case it was actually a Chevy grille with the bowtie. Looked alot like the grille on the 94 Chev work van that I drive. The fenders are in great shape, rad support has some scale on it, the bumper was straight but had some chrome bubbling/rust at drivers lower side about the size of a silver dollar.
He doesn't want to give the wiring harness as he wants to keep it with the engine and frame to adapt to the 1937 Ford truck he is building.
Are there several different grilles in 91 and are the rad supports all the same?
Found picture of a 91 burb with the same grille
Old 12-03-2009, 08:13 AM   #8
csa daddy
csa daddy's Avatar
two diff types if i remember right an i think its all diff i might be wrong though
csa daddy is offline   Reply With Quote
Old 12-03-2009, 09:05 AM   #9
silvereagle07
silvereagle07's Avatar
Yeah there are two different types. You need to find one from a 1500 series. The wiring harness you need only goes to the lights and washer bottle. There are out there, keep searching.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 12-03-2009, 09:41 AM   #10
Jonboy
That is the base model grille (with the single headlamps). If you are going to swap, I would find teh ones with dual headlamps, to make it worth your time (IMO).
Old 12-03-2009, 11:13 AM   #11
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
i second jonboys opinion
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 12-03-2009, 02:37 PM   #12
72 CustomCamper
huh ???
1500, 2500, 3500 doesn't matter. He needs one from a Silverado. The burb he shown is a Scottsdale...
Chuck
Old 12-03-2009, 05:25 PM   #13
BGRAFX
I did a reverse front end swap but here are some pics I started with a 91suburban and went backwards 10yrs to 1981. (the year I was born)
BGRAFX is offline   Reply With Quote
