Old 12-03-2009, 11:29 PM   #1
67_ShortFleet
67_ShortFleet's Avatar
Re: Project 50th C5 Blazer
Originally Posted by Twisted78SS View Post
I finally found a picture of a restored 50th. This truck belongs to Rick Parsons, and the article is in Truck Builder Magazine http://truckbuildermagazine.com/ME2/...49EDD04DB2C706
Pretty Damn nice ride!
This helps me to visualize mine.. I am going to attempt doing a Photoshop onto a Blazer with the color scheme.
I like that color combo also. Ever since I found a picture of the crew cab with those colors I have liked it.
Do you know where a guy could find more pictures of this truck. The link does not work. Is the magazine no longer published? I wish I could see that issue.
Thanks Matt
67_ShortFleet is offline   Reply With Quote
Old 12-03-2009, 11:58 PM   #2
KMACD71
KMACD71's Avatar
Thanks Matt
Here's a link to Classic Truck mag. feature:http://www.classictrucks.com/feature...c10/index.html
KMACD71 is offline   Reply With Quote
Old 12-04-2009, 09:22 AM   #3
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Here's one of the CrewCab.
ChuckDriver is offline   Reply With Quote
Old 12-04-2009, 02:26 PM   #4
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I made a copy from my issue of the Truck Builder article on Rick Parsons truck, you can download it here in PDF format.
http://www.2heeldrive.com/brochures/...dWhite68_2.pdf
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 12-07-2009, 07:52 PM   #5
Twisted78SS
Wide n'Low
I got a little clean-up done to the new winter driver, I swapped out the grill and took the really bent bumper off and in place put the free slightly bent bumper on.. Still it looks way better to me already. I also noticed while doing an oil change I have the front left axle seal weeping a bit. Guess I had better take care of that right away... Here is a shot of how it looks today.
I did spend a couple of minutes trying to see if there was any shine left to the paint, at least it can look respectable for the winter. Turns out that it comes back pretty easy. If you look on the hood, you can see the spot I cleaned and waxed. Back in the shop it goes to give it the once over.
I also had to remove and re-do the power steering brackets, the PO. had left two bolts out and it was allowing the pump to move around, and the belt was slipping.
Air Force Retired
Old 04-05-2010, 08:23 PM   #6
Twisted78SS
Wide n'Low
Link seems to be dead, here is another article
Air Force Retired
Old 09-03-2011, 02:25 PM   #7
HarrolLS1
HarrolLS1's Avatar
Thanks Matt
Try this link to the pdf of the article:
Too much goofing off on a Saturday... I should be out in the garage
Harrol
1968 SWB
1968 SWB 4x4
1969 Suburban
1970 LWB
1970 Blazer
2002 Tahoe
Inside every older person is a younger person wondering what happened
HarrolLS1 is offline   Reply With Quote
