Old 12-04-2009, 12:46 PM   #1
ClassicDreamer
Daily Drivers?
Thinking about buying an early 60's c10 as a daily driver. Eventually want to do bags on it, but no other major mods. Is this practical? I love in the New York, while our winters are not terrible how do these trucks handle in snow? I am in the middle of building my 54 3100 now and looking for a daily.
Advise on what to look for when buying? Floor and cab corner rot? Any info would be great
ClassicDreamer is offline   Reply With Quote
Old 12-04-2009, 07:07 PM   #2
816allen
816allen's Avatar
Re: Daily Drivers?
I wouldnt bag it if its gonna be your daily ive seen guys at work with bagged trucks and there bad @$$ but i also seen them stuck on the side of the highway too....I drive mine every day its been great to me i love this truck!
Stock motor and trans too havnt rolled in the snow yet with it but i say bring it on i have snow tires ready.
96 Burban Sold
99 Z71 Sold
65 C10 Sold
72 C10 Sold
87 Short Bed Lowered Daily Driver
http://s623.photobucket.com/albums/tt314/sswagon/
http://www.chevygmcofkc.org/forums/forum.php
816allen is offline   Reply With Quote
Old 12-04-2009, 07:38 PM   #3
LILRED66
LILRED66's Avatar
Re: Daily Drivers?
This is a good source of information, if you are prospecting a '60-'66 Chevy/GMC truck:
http://www.stovebolt.com/techtips/bu...uide_60_66.htm
LILRED66 is offline   Reply With Quote
Old 12-04-2009, 07:54 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Daily Drivers?
I had trouble getting around in the snow and ice until I put about 300 pounds of sand bags over the axle, after that it got around great.
Old 12-04-2009, 08:17 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Daily Drivers?
I'd be a little skeptical about bags if it's going to be regularly driven in sub freezing weather, not sure how the air pressure changes would affect handling - although big rigs have been using air suspension for decades. Hopefully you'll get some opinions from guys that are currently driving bagged trucks in winter conditions.
When my 60 GMC was a daily driver I also ran about 300 lbs of sand bags under a Gaylord bed cover. I no longer run the bed cover, and because my fuel fill is now in the bed floor I don't use sand bags either. With studded snow tires as the only traction aid it's really squirrelly on slick roads.
I no longer drive it during bad weather, but if I did - I'd pull the aluminum diamond plate bed floor and switch to a steel replacement for the added weight.
Old 12-04-2009, 08:59 PM   #6
Indian113
Indian113's Avatar
Re: Daily Drivers?
I have driven my wifes 64 stepside in the rain,with 300 hp and 373 gear whew lots of fun snow would be worse. short wheelbase and no weight in box means trouble
Indian113 is offline   Reply With Quote
Old 12-05-2009, 02:25 AM   #7
Captainfab
60-66 Nut
Re: Daily Drivers?
A posi, some good tires, and as already said some extra weight over the rear axle, and it'll go pretty good. Not 4x4 good but it is doable. My '66 Suburban was a year round daily for several years. Now I don't drive it in the winter unless I have to. The damn road de-icer really took it's toll on her
Old 12-05-2009, 05:52 PM   #8
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Re: Daily Drivers?
I've driven both by '63 and '62 daily for almost ten years. Theyare both on air bags and I have never had any trouble.
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 12-05-2009, 08:01 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Daily Drivers?
i havn't taken my 66 in snow (nor would i), but I can comment on bags in winter
I live in wi and drove a bagged s10 through 2 winters. Reliability in snow/ice is greatly affected by what type of setup you go with.
The bags themselves are made of the same stuff as tires, so no worries about salt or anything getting on them. Electric compressors will draw a little more current in the cold just because of the piston tolerance; may or not be a problem depending on your battery/alt combo. Bagged rides (especially without shocks/swaybar setups) are bouncy/floaty sometimes, so mixed with ice/snow it can test your nerves if you get into a hairy situation.
In terms of maintenance and reliability the biggest things are; drain your air tank(s) down at the end of fall, making sure to get out any water, then use brake line antifreeze in the system to prevent valves from freezing.
Make sure your relays, and wiring is insulated and away from salt/ice etc. If you don't there is a chance you can erode the terminals and the connection will break right off (happend 2 me twice until i switched to a weather-sealed relay).
I would also recommend putting your valves in the bed, or protected somehow, as salt getting into the valves can damage the diaphram, or stick a valve open leaving you stranded (check valves help too).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-09-2009, 01:12 PM   #10
MikeN
MikeN's Avatar
Re: Daily Drivers?
I drive mine to work every day for 10+ years, 40 mile round trip. All stock except for a 350 in place of the original inline-6.
MikeN is online now   Reply With Quote
