10-24-2009, 05:39 PM | #1 |
indash cd player?
how are u guys installing these newer cd players in our trucks?
which color goes to what? iv been wanting to install an indash player in my truck! |
10-25-2009, 04:39 PM | #2 |
Re: indash cd player?
cutting it making a new panel etc,,,
10-25-2009, 05:50 PM | #3 |
i know how to install it but im talking about the wires!
10-26-2009, 03:40 PM | #4 |
oh idk they make an easy plug harness even for these 80s trucks though
10-26-2009, 09:13 PM | #5 |
Look up the wires? There are only a few.
____________________________________ |
11-04-2009, 12:56 AM | #6 |
6.0 powered square
Just trace the wire and see what constant hot and switched with a test light or volt meter and a good ground for the speaker wire I would start with new
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
12-01-2009, 01:40 PM | #7 |
im not sure what year truck you have,in my 70 i ran the wires to the cig and radio spots on the fuse box, not sure which to which, theres a thread on a build i can try and find for you also.
70 Chevy C10, LT1, T5, "Blue Beast" |
12-04-2009, 05:00 AM | #8 |
basically all u need to do is hook the yellow to 12 volt all the time red to ignition (power with key on) and then your black to ground then wire up your speakers if you r having troubles ur test light will be your best freind ull get it its easy
84 3/4ton swap 4x4, 409sbc 37x13.50 toyos 8 inch superlift 2007 2500 HD, 10-12 cognito lift, 38x13.50 toyos soon to be boosted via rearmount system |
12-04-2009, 09:05 PM | #9 |
Grandpa in the rustmobile...
If your bought it new it shouldve came with a little wiring harness and book telling u what wires are what
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
