12-04-2009, 06:02 PM | #1 |
camshaft remover
does anyone know where to get a camshaft remover or if there are any other ways to remove your cam?
and secondly which kind of puller works best for removing the lower timing gear sprocket? thanks! |
12-04-2009, 06:06 PM | #2 |
Its a Truck Thing......
Re: camshaft remover
I always use a 2 jaw puller to remove the pulley, I use longer bolts and pull the cam right out, never had problems, make sure the lifters are out first........
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
12-04-2009, 06:12 PM | #3 |
Here's a link to the ones Summit Racing has
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc |
12-04-2009, 07:05 PM | #4 |
use a 6 inch bolt
12-04-2009, 08:04 PM | #5 |
good to do b4 removing is read service manual
12-05-2009, 12:37 AM | #6 |
When my son and his friend did a cam swap, they just started taking stuff apart. Whatever was on the intake wound up in the intake runners. I don't know if the same care was taken putting it back together or if it happened on teardown but somehow a washer wound up in #5 cylinder. Beat the living crap out of the piston and ruined the head. I still don't know if the block is ok. It was a 2000 mile crate 350. Very sad day. |
12-05-2009, 01:47 AM | #7 | |
12-05-2009, 09:48 AM | #8 |
PROJECT 7DEUCE
I just use long bolts and carefully slide the cam out..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-05-2009, 01:09 PM | #9 |
thanks for the responses! i got it out and it was the fuel pushrod. it was right in front of me and i didnt see it hah. i just pulled the fuel pump and it came right out. i can really make myself feel really stupid sometimes lol.
12-05-2009, 01:18 PM | #10 |
If you would have stated that you were having trouble I would have told you to check it.
I try not to offer to much advice anymore. Apparently there are those who will get offended. |
