12-05-2009, 10:48 PM | #1 |
Easy Does It
will 60-62 cabs fit on 63-66 frames?
I have a nice 63-66 frame, and I was wondering if the mounts were diffrent on the 60-62 cabs? has anyone done this swap? thanks
12-05-2009, 10:58 PM | #2 |
Re: will 60-62 cabs fit on 63-66 frames?
NO, As I understand the front mounts are in a different position. This is on the BB somewhere, do a quick search.
http://s1299.photobucket.com/user/jb...23904108567829 |
12-06-2009, 04:00 AM | #3 |
yes they fit, but the front cab mount is narrower on the later slyle frame. i just redrilled mine and cut a peep hole in the floor brace to bolt it up.
Projects: 66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350. |
12-06-2009, 07:27 AM | #4 |
UCA63
Don't forget about the hydrualic clutch set up
Check out Txfirefighters' thread, he's doing what your asking,with pics too T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
12-06-2009, 09:13 AM | #5 |
1961 crewcab
The rear mounts are the same.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-06-2009, 05:23 PM | #6 |
1# Drobmember in Germany
I do it the same way , 63 Frame to a 61 Body , take a look to the picīs :
Front Driverside i hope it helpīs ! Pat |
12-06-2009, 08:57 PM | #7 |
You can also get the rivited front mounts on the 60-62 frame and bolt it to the 63-66 frame. That would make it look stock.
