#26 |
Re: What brand of spark plug?
I have used Autolites....After 30 years,I've never had any trouble.
I have bought one set of AC Delco....One died after about a month, Replaced it with one of the old Autolites I removed. That was my first and last set of AC's
70 C/10 LWB 69 Cougar 68 Mustang 68 GMC 4X4 SWB |
#27 | |
I run AC Delco R45TS in mine with 50,000 volt HEI and 8.8mm accel wires. Champions are junk Autolites are not far behind. |
#28 |
NGK UR4 v-power's, had the best luck with these
'72 cheyenne super step, '05 long bed gmc |
#29 |
A split plug is an attempt to compensate for a weak ignition.if you want more or hotter spark,start with the distributor/coil.A standard plug will take all you can give it.
Here`s a fun little thing.Take a champion spark plug and any other spark plug,hold both at the base,and strike the porceline together.Every time the champion will break.
#30 |
more ideas than money
I am really suprised at all of the hate for autolite!?
![]() 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
#31 |
#32 |
Same here....never had a problem with my autolites. Running a set of 8924's in my aluminum heads gapped @.045, barely rolls over once before it fires right up.
'72 Chevy C10 383, 700r4, 3.73's A little rust never hurt anyone. I consider it weight reduction. |
#33 | |
#34 |
Andy
NGK in everything. Just got a set today to replace the AC's that are in my Nova.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi 1969 CST/10 383|Aisin AR5 5 speed 1972 K5 350|Turbo 350 4x4 2005 Duramax 2500HD 4x4 |
#35 |
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() |
#36 |
Plain black AC plugs in everything for me (even the lawn mowers). Autolites are crap in my opinion. But then again they are made by the same company that makes FRAM oil filters. Maybe that's why I won't let one near anything I own.
-Tony Money is no object... once it's in your wife's hands. 1972 GMC Sierra 1977 Ford LTD II 2000 Pontiac Grand Prix (wife's ride) |
#37 |
Trucks N Tranzams
AC Delco or NGK. Both are top notch.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
#38 |
Champion in my atv, AC Delco in my S10, E3 in my c10 and Silverado and Autolite in my 2 F#%?s
#39 |
Ac Delco without a doubt, as Shane said, if GM trusts them I guess I can too. Ditto on the champions, they suck!!
#40 |
Well, basically from what I can tell in this thread, AC Delco is the top choice (by popularity anyway) and Champions suck @&&.
Autolites appear to be somewhat neutral................. |
#41 |
Grand PooBaa Member
My truck was running terrible so before I checked each plug and this is what I found. My Autolite Platiumn which are bout 2 months old are fouled out and checkout the one below. When I pulled the plug boot off, the porcelin drop out of the boot. Done with Autolites!
#42 |
Autolites not so neutral again...........
#43 |
Gone to greener pastures
![]() Join Date: May 2007
ACCEL shorties, because ACs won't fit behind the headers.
Many, many moons ago, my Dad, who specialized in/did only tune ups & carburetors, was sent to the GM Training Center in Burbank, CA. He was told/taught to use OEM spark plugs; i.e. AC Delco for GM, Autolite for Ford, etc. What he taught me has worked for me for more than a few decades.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#44 |
#45 | |
Secondly, if you're going to be sarcastic why don't you quote someone so we can figure out what order we're going to start yelling at you? Last edited by highperf4x4; 12-06-2009 at 01:03 PM. |
#46 |
Moderator
AC Delco
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#47 |
Any plugs with the word "copper, platinum, iridium, etc" in the title are good for one thing: draining your wallet. If you have a newer engine with ignition systems that require platimum plugs then that's understandable, but these engines aren't state of the art technology. It's like putting a hubcap on a tractor. It might look purdy, but other than that it serves no purpose. But far be it from me to tell people how to waste their own money...
#48 |
LET'S GO RACIN'
![]() Join Date: Oct 2007
Have used Autolites for years. We have even used them in the dirt track car. Never had a problem.
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY ![]() Rip El Jay RIP BOBBO'S MOM |
#49 |
Grand PooBaa Member
This was the first time I ever used Autolites, normally I Champion's were in my truck. Thought I would try something different. Now my engine is in need of a rebuild so I dont expect the plug to make it that much better.
Heck I dont know, I came here to see what was the plug of choice was, but it looks like were all using what works for us. I bought NGK's, and I will keep you posted. |
#50 |
Chemist under the hood...
I think this is really the Coke vs Pepsi for most except high performance. I took out a really old set of Champions in the 283. Replaced them with another set of Champion (same type). No issues so far. I'm not drag racing this 42 year old engine. I probably will go for AC Delco next time (I usually go OEM and didn't think about that when I bought the Champions since they were already there).
My Astro van and Caprice wagon are AC Delco. My wife's Mazda has Bosch Iridium but that's fuel injected and there's only 4 plugs to buy so who cares. ![]()
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
