Need help re: 71 Blazer Engine Mounting
Pulled the 454 engine in my 1971 Blazer and got it rebuilt...problem is:::
i dropped it back in and mounted it up but the valve covers are too tight up against the firewall...just no way it could be right! not even room for some engine movement. do the mounting brackets have a right and left side? could i have them backwards? seems like it should be easy, the block and frame only have one set of holes? lost...
Russ Ellis 'Cruizin' the Valley' - Custom Classics "The Guyz Garage" ![]() Last edited by azngosh8r; 12-07-2009 at 01:48 PM. Reason: typo |
![]() Join Date: May 2007
Re: Need help re: 71 Blazer Engine Mounting
What changed while it was out? Did you go with different valve covers, heads,etc?
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
no changes at all...new valve covers but same style and shape....thats what has me confused...i feel like im losin my mind...
Strongman Garage
![]() Join Date: Apr 2000
The valve covers are probably a little taller/different.
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
New motor mounts? Something HAS to be different. It's probably something simple.
