Old 12-06-2009, 03:38 PM   #1
oldno7
oldno7's Avatar
sandblasting
I'm going to be sandblasting my frame soon and want your opinions on what I should use. I've done this befor and used white silicone sand. Since then I've found out that probably wasn't a good idea since you can get silicosis. This would be the reason I had some issue breathing afterward should have used a better respirator lesson lert.
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 12-06-2009, 05:34 PM   #2
Strut
Strut's Avatar
Re: sandblasting
I used Black Beauty Media on my sheet metal. Works real good.....
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 12-06-2009, 08:29 PM   #3
Mowdigger
Mowdigger's Avatar
Re: sandblasting
Use the Black Beauty on the frame, it is a little more aggressive than the sand and works well. Thats what I used on mine.
Mowdigger is offline   Reply With Quote
Old 12-06-2009, 08:44 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: sandblasting
I've been known to paint large vehicles in a small non ventilated garage, I'll sand paint and filler with no mask at all... I've even cleaned public toilets with no rubber gloves (way back in the day)...
However, when blasting with ANY media, ALWAYS wear some sort of mask.
Old 12-06-2009, 09:49 PM   #5
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: sandblasting
that silica sand it BAD stuff, stick with the commercially available medias. Most any will do OK, black beauty is one that will do better than others.
Oh, and I agree that you should wear a respirator.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 12-06-2009, 09:57 PM   #6
mr48chev
mr48chev's Avatar
Re: sandblasting
Wear a good respirator (not just a dust mask) no matter what media you use. I'm not as up on the different medias as some of the other guys but Silica sand makes for a lot of dust floating in the air anytime you use it.
Old 12-06-2009, 10:34 PM   #7
beechd18
Re: sandblasting
If there is some one close by that dose it I would have it done. I weighed the options and it was cheaper to have it done over doing it my self. I just had mine blasted Friday.
beechd18 is offline   Reply With Quote
Old 12-07-2009, 12:21 AM   #8
seafoam68
seafoam68's Avatar
Re: sandblasting
I have done a lot of my own blasting. The problem with using "black beauty" and other media agents is the incrediable cost involved. I have "broke the law" and used a premium play sand available from Lowes. It is screened to one size and works well and only 3.50 a bag. It is important to note, however, I wrap up like a mummy with full eye, ear and lung protection. Don't skimp on a cheap respirator !
seafoam68 is offline   Reply With Quote
Old 12-07-2009, 12:37 AM   #9
beechd18
Re: sandblasting
To each his own I would rather pay the $90 bucks.
Old 12-07-2009, 11:02 PM   #10
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
Re: sandblasting
What would you guys prefer for a good sand blastin set up
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[COMPLETE-EDELBROCK]
[PERFORMANCE-SERIES]
[CAM_CARB_MANIFOLD]
...TURBO-400_TRANNY...
CUSTOM_1O is offline   Reply With Quote
Old 12-07-2009, 11:53 PM   #11
cdowns
cdowns's Avatar
Re: sandblasting
got this one about 25years ago have saved and made in the tens of thousands of dollars with it if i had to pay someone to blast my stuff
Old 12-08-2009, 12:36 AM   #12
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
Re: sandblasting
WHERE COULD I FIND MYSELF ONE???
IVE HEARD THAT YOU CAN BUY THE SAND BLASTING GUN AND JUST HOOK IT UP TO A REGULAR AIR COMPRESSOR TRUE OR FALSE??? AND IF SO IM SURE ITS NOT THAT SIMPLE WHAT ELSE WOULD BE NEEDED??? A ADDED REGULATOR N ETC???
THNKS FOR UR TIME
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[CAM_CARB_MANIFOLD]
Old 12-08-2009, 12:53 AM   #13
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Re: sandblasting
If you got a local tractor supply or something of the sort you can usually pick up a 20 gallon one similar to the one above for baout $125. Personally we got a guy in town who will blast an entire frame perfectly for $100. You got to remember sand is anywhere from $4 to $8 a bag any more and then tips for those sandblaster are about $15 for four. I've found its about one tip for every two bags. So add it all up and its cheaper to take it somewhere.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 12-08-2009, 01:07 AM   #14
beechd18
Re: sandblasting
Your as lucky as I am I got a local place that did my frame for $90. I figured I would have that in sand. They also did it while I waited. In one hour it was done. But I could see that some guy's would like to do it there self or do more than one frame then it might pay off.
Old 12-08-2009, 11:59 AM   #15
brothers69c-10
Suburban Hick
Re: sandblasting
I tried doing some things myself, like some of the small stuff and i gave up on it when i had got about $100 worth of supplies in a set of rims that i tried to sandblast at home and they still aren"t done.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 12-08-2009, 05:59 PM   #16
CUSTOM_1O
HaV0KSR559<~~~
CUSTOM_1O's Avatar
Re: sandblasting
Id rather do it myself...
Because i dont know of ne one around here who would do it
or of ne one who even has a blaster and if they did i would know
of top it would be cheaper to do it myself...
...1969_CUSTOM_1O
FLEETSIDE_LONGBED
V8_THREE-FIFTY
[CAM_CARB_MANIFOLD]
