help with 61 c10 rearend
can anyone tell me what this set up is on my 61 c10
is the 2nd spring just a helper i have a set of 3 inch drop blocks i want to install if i install drop blocks will it affect the shock in the rear any help thanks ![]() Last edited by rain_man; 12-09-2009 at 02:30 PM. |
Re: help with 61 c10 rearend
The spring above the axle /U-bolt is an addon, and the blocks should just keep the shock where it is in relation to the trailing arm but lower than the axle by the thickness of the block
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
