Truck arm rear suspension
Anyone put a 67-72 rear suspension in a 73-87?
I ran across a conversion kit on CPP's site, but not pics or info, just a $1200 price. Here is one from hotrods to hell... http://www.hotrodstohell.net/in_the_works/hillbilly.htm Looks like there kits run around $2000
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 12-09-2009 at 05:19 AM. |
#2 | |
Still plays with trucks
Re: Truck arm rear suspension
If you did it right you could put the leaf spring stuff back on the donor rig and sell it off to recover some or all of your investment. I see them as truck bed trailers every now and then for $150 to $300.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E Last edited by 68 TT; 12-09-2009 at 10:04 AM. |
Happy to be here
![]() Join Date: Mar 2000
There was a thread going in the suspension section on this topic. Do a search there and see if it pulls up. If not I will try to locate it later.....
here ya go. I've been watching this for future reference.
http://67-72chevytrucks.com/vboard/s...d.php?t=364043
I can still count my vehicles on two... wait three hands. |
do it,
pick up a scrap $200 truck and scalp all the rear stuff of it. 63-72 |
Thanks guys, thats a great thread with lots of good info. I couldnt find it b/c I was searching for truck arms and not trailing arms.
Now I've got something else to add to the list of things to do. Check the other thread for the article on the CPP kit. It dosent seem like a bad price for everything it includes. 68 TT, that was exactly what I was thinking..... now to find a cheap truck..... Any difference in arm length between long and short bed??
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 12-10-2009 at 05:12 AM. |
http://www.classicperform.com/Videos/Videos.htm
Look at the bottom screen on the lower left. The video is titled '79 C-10 Truck. Pretty nice. I'm planning a call to CPP tomorrow, I'll see if I can get anymore info on the truck. I'd like to know how much drop the springs on it are. I know those modular spindles are 2". According to the article they used a 3" spring in back, but the video dosent say what spring was used up front. Love that stance on this truck and it corners so flat.... Install article on the kit: http://www.classicperform.com/tech_a...iling_Arms.htm
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 12-11-2009 at 03:55 AM. |
For 2 grand you can get a bolt on air bag 4 link from ride tech.
Ya, but then I'd need an air management system, and I'd want to do the front too and im in it for 4-5k by the time its all done.
I'm thinking with a used set of arms, new bushings and some powdercoat on those and the CPP kit (-arms is 609) and could bring the trailing arm setup in for under a grand and be done....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
nope, they are the same length I have been thinking about doing this conversion for some time. We have a '66 with coils in the rear, and I really like how it rides and handles. I think I can even get all the stuff for free. My wife's uncle has several 64-66's sitting in his field ![]() pretty sure the trailing arm cross member will need to be modified to fit the newer frame, shouldn't be bad though.....
![]() ![]() Last edited by joe231; 12-11-2009 at 12:06 PM. |
That is good to know. I plan on turning my long bed C-10 into a short bed. Glad to know I don't need to mess with the truck arm stuff too.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
I really hate wet sanding!
![]() Join Date: Dec 2008
3/4 tons are the same too, but the trailing arms are re-enforced to make them stronger.
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
How are they reinforced? Any pics of the two for comparison?
Always a work in progress
I plan on doing the same thing as well to my 85. There are quite a few trucks in the pull a part yard that I can pick from so I will go that route and hopefully keep the cost under $300
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
#15 |
what advantage is going older truck coil and trailing arm!????
#16 | |
the ride is way smoother, traction is better, and the cornering and handling are better also. You can adapt bags or coil overs rather easily also. Makes for a nice corner carver.... I believe there are guys running 9's and 10's in the quarter mile with the stock arms.
![]() ![]() Last edited by joe231; 12-11-2009 at 03:56 PM. |
#17 | |
#18 | |
Just got off the phone with CPP. Kit is designed for 63-72 arms and will work with a stock set of arms. The truck in that video uses their modular brake kit with a 2" drop spindle They also used a 2" drop spring up front for 4" total. Their rear arms have no drop built into them and the truck has 3" 63-72 drop coils in the rear, or can use any other drop or stock spring for those years. I'm thinking you will get another 2-3" drop out of the swap due to the axle being located on the top of the arms, so this truck would have a 4/6 or so drop from stock. Now I just need some arms and 6 bills.....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 12-11-2009 at 06:21 PM. |
#19 |
I'm pretty sure I seen a magazine tech article where they were installing the cpp kit on a mid-late 70s short bed. I believe it was classic trucks, probably 3 years ago, I would try and find it but i'm pretty sure it got left behind when I moved back from Michigan.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 ![]() 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
#20 |
the 3/4 tons are clad with a additional 1/8" plate on the top and bottom.
i will have a set of half tons that i dont need, hit me up if you want to work out how to ship them. |
#21 | |
It is linked in this thread on post #7. Also linked in the thread in post #4 in the suspension forum.
#22 | |
My 67 body will be going onto the 78 K20 chassis and the 78 body will be going onto the 67 C-10 truck arm chassis. Both are long beds but the 78 will become a short bed eventually. The wheel base of the 78 body is a little longer than the 67 so a little frame modification will be needed on both rigs.
#23 |
HORSEPOWER JUNKIE
even nascar runs this style suspension
67 C20 fleetside custom camper 69 El Camino 72 Camaro 52 Dodge b3b 108 pickup |
#24 |
At the body shop.
leaf springs and cal trac bars have done 8's on 10.5 tires
" That didnt make it any newer " " Dont antique the equipment " |
#25 | |
They don't let the rear end articulate like it needs to so the vehicle has good street manners. Most guys who run them on the street and track back off the link bar so they have a pretty good gap at the front pivot bolt when they take the car on the street. This diminishes their straight line capabilities quite a bit. It only takes a minute to make the change but for something like CPP's truck doing auto-x the Cal-Trac bar just won't behave well. Truck arm is far superior here.
