Old 12-11-2009, 11:11 PM   #1
Stitch
Location: Where I come from, it's cornbread and chicken...
want opinions and pics
I'm thinking about maybe taking my truck and putting a cab and chassis rear under it and putting some 19.5s on it and lowering it down some...I like the look of dually wheels, but I don't think a regular cab swb dually would look good with the fenders on the bed and the truck being so short...so I thought maybe get a cab and chassis rear and tuck the wheels up under the fleetside bed sides...just a thought...what do yall think...
Chuck.
Stitch is offline   Reply With Quote
Old 12-12-2009, 01:18 AM   #2
wfomkivdrvr
HORSEPOWER JUNKIE
wfomkivdrvr's Avatar
Re: want opinions and pics
I've seen pictures of a fleetside with that set up with standard off set dually rims the tires only come out of the fenders about an 1 in 1.5 in it didnt look bad at all some small flares and your all set
67 C20 fleetside custom camper
69 El Camino
72 Camaro
52 Dodge b3b 108 pickup
wfomkivdrvr is offline   Reply With Quote
Old 12-12-2009, 01:27 AM   #3
Stitch
I'd rather shorten the axles and have all of the wheel/tire up under the bed...
Old 12-12-2009, 01:32 AM   #4
2tons of fun
you will have too.
get a you 14bff and find a second short shaft and knock the differance out of the longshaft tube, install short shaft and you are now atleast 3" narrower.
2tons of fun is offline   Reply With Quote
Old 12-12-2009, 01:37 AM   #5
Stitch
and then it'll fit up under the bed right? do you think I should just extend the wheel wells out like factory...I'd like to do this for the look, because I don't think I'll ever tow a fifth wheel trailer or anything, I don't even know if my 6.2 would tow it...I just thought it would be cool to see...
Old 12-12-2009, 01:38 AM   #6
wfomkivdrvr
HORSEPOWER JUNKIE
found the pic
69 El Camino
72 Camaro
Old 12-12-2009, 01:40 AM   #7
Stitch
see now if I could get the wheels under the bed like 2tons of fun said, then I'd be in business...I also think I'm going to put cab lights up on the roof whether I put drw axle under it or not...
Old 12-12-2009, 01:45 AM   #8
wfomkivdrvr
HORSEPOWER JUNKIE
you will have to relocate the leaf springs a cab chassis axle has the tires real close too the leafs
69 El Camino
72 Camaro
Old 12-12-2009, 01:49 AM   #9
Stitch
that's no problem...shortening the axle is what worries me
Old 12-12-2009, 01:53 AM   #10
wfomkivdrvr
HORSEPOWER JUNKIE
thats not a problem they do that for drag cars and crawlers all the time!
69 El Camino
72 Camaro
Old 12-12-2009, 01:56 AM   #11
Stitch
is shortening the housing and putting a shortside shaft in the longside doable by me or do I need to take it to a specialist?
Old 12-12-2009, 02:04 AM   #12
wfomkivdrvr
HORSEPOWER JUNKIE
that depends on your welding skills how well can you weld .500 wall tube?
69 El Camino
72 Camaro
Old 12-12-2009, 02:13 AM   #13
Stitch
I have a good friend of mine that can weld it...is it just a matter of measuring the axle tube, welding it and then sliding a shortside shaft in there or does the shaft need to be shortened as well?
Old 12-12-2009, 02:33 AM   #14
wfomkivdrvr
HORSEPOWER JUNKIE
that depends on how much you shorten it but yes you can install a short shaft in there with out a problem just like 2 ton of fun said!
69 El Camino
72 Camaro
