Old 12-04-2009, 12:54 AM   #1
gmc1971harwich
gmc1971harwich's Avatar
need help with non-tilt auto column
please help im tearing my hair out i reinstalled this auto column into my truck but when i put in the turn signal housing i got it to line up with the gear indicator but it keeps moving around on me. is it supposed to lock in place? i know theres tabs that the housing has to go under and turn but wont stop moving the turn signal help guys thanks!
also this shaft up by the steering wheel must be a different size because the 3/4 nut from my old tilt column doesnt fit when i put the steering wheel on.
gmc1971harwich is offline   Reply With Quote
Old 12-04-2009, 06:45 AM   #2
JimKshortstep4x4
Re: need help with non-tilt auto column
I believe the three mounting screws will lock the housing in place. Are they tight?
The tilt column has a larger different nut then the standard column.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-05-2009, 06:57 PM   #3
gmc1971harwich
yea i checked the screws are tight but it still turns is it supposed to lock in some how?
Old 12-13-2009, 02:54 PM   #4
KiDD3
I'm having the same issue. There seems to be enough gap between the wheel and the housing that nothing stays tight. I actually have to somewhat hold the housing when I use my turn signals. I changed the steer column and reused the housing and parts from my old housing, being that the housing on the replacement was junk.
Anyone have ideas on how to get a tight fit??
Pardon my questions...I'm a noob on a mission.
KiDD3 is offline   Reply With Quote
