12-12-2009, 09:25 PM | #1 |
84 A arms on a 72
any advantages on putting 84A arms on a 72 that has factory disc brakes? better ball joints or anything?
12-13-2009, 12:21 AM | #2 |
Re: 84 A arms on a 72
The later arms have rubber bushings instead of metal bushings. Some will tell you the rubber bushings ride better. I know the ball joints are different too, but I doubt they are much better. The BJ tapers are different from 72 to 73 which dictates the correct spindle and tie rod ends.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
12-13-2009, 11:42 AM | #3 |
Ball joints are quite a bit cheaper. I think the stud is a little bigger also.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-13-2009, 08:00 PM | #4 |
so---would this be a good swap?
12-13-2009, 08:13 PM | #5 |
my opinion would be yes. the only benefit i have "heard" of (since i've never used the 67-72 type) is that the 67-72 versions handle better since there is less rubber deflection for cornering/handling. the advantages are softer ride unless you use urethane cuz they are stiffer, cheaper replacement costs, IMO easier to change, no servicing (no zerks to grease), and easier to find.
i changed my blazer to 73 up before i drove it and am doing the same on the 71 even though it is already a 5 lug and disc brake setup.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
12-13-2009, 10:10 PM | #6 |
so then, are front end parts cheaper for a 73 than a 72? I want to rebuild the front end of my 72 and go with drop spindles
12-13-2009, 10:34 PM | #7 |
gets board easy.......
put 73 and up spindles on it, and change over to 73 and up ball joints.
Might have to change tie rod ends too? the 73 and up have bigger peices |
12-13-2009, 11:41 PM | #8 |
yea, most all parts are cheaper and easier to find for 73 up, and more parts are stocked locally @ parts stores too. even the spindles can be found cheaper if you search.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project Last edited by lofly'a; 12-13-2009 at 11:43 PM. |
