12-11-2009, 11:52 PM | #1 |
Hydra-Boost
I was wondering if you guys know where I can get a Hydra-Boost(edit for spelling). Someone stole the one out of my 1 Ton 454 truck. They even took the powersteering pump.
I can't seem to find one out here. Thanks guys. |
12-11-2009, 11:56 PM | #2 |
Formerly- 1972SuperCheyenne
Re: Hydra-Boost
No local salvage yards out there? That would be the only place I can think of that you could get everything at one place for a decent price.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
12-12-2009, 12:04 AM | #3 |
Re: Hydra-Boost
I have one I haven't checked yet. Do you have any idea what they would go for? Could I just swith it over to Vacuum Booster? The truck is a 10,000 GVW Camper Special with the Dana 70 rear. I know the Hydra-Boost is better but if I can't find one I will be stuck for a while.
12-12-2009, 12:18 AM | #4 |
Location: Where I come from, it's cornbread and chicken...
Re: Hydra-Boost
if it had hydraboost brakes, chances are it had a diesel in it from the factory...if it doesn't have a diesel anymore, I don't see why you would need hydraboost brakes...someone correct me if I'm wrong
12-12-2009, 12:28 AM | #5 |
Re: Hydra-Boost
Nope. The Big Blocks came with this type of braking system. Not all Big blocks but many did.I have had 2 454 1979 trucks with the Hydra-Boost. The truck I have now is an original 454/400 truck.
12-12-2009, 12:32 AM | #6 |
Re: Hydra-Boost
well, like the diesel if it came with the hydraboost brakes because of the 454 and no longer has the 454, is the hydraboost needed...
12-12-2009, 12:38 AM | #7 |
Gettin It One Pice At A Time
Re: Hydra-Boost
I think it has more to do with the tonnage. I thought most 1 ton's came with hydra boost to help with heaver loads. at any rate. I would look some for a hydra boost first as I think it would be easier to just bolt in then buy and convert to a PB set up. I would imagine you would loose some braking performance......?
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
12-12-2009, 12:51 AM | #8 |
Re: Hydra-Boost
12-12-2009, 12:59 AM | #9 |
Re: Hydra-Boost
ah ha...then I say leave it stock and find you a hydraboost setup in a yard somewhere...maybe you can find a yard that will ship you one...I may be going to a pullapart around here soon...I'll look for one for you if you want...
12-12-2009, 01:18 AM | #10 |
Re: Hydra-Boost
My dads 80 1 ton 350/4spd also has the hydra-boost, and i've seen a couple other small block trucks with them as well.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
12-12-2009, 01:28 AM | #11 |
Kid's Mechanic
Re: Hydra-Boost
My one ton with a small block has it too.
12-12-2009, 06:48 AM | #12 | |
Conversion Truck Addicted
Re: Hydra-Boost
You can buy a reman from rockauto
Thomas Quote:
12-13-2009, 06:13 PM | #13 |
Re: Hydra-Boost
you can buy it all new through NAPA
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
12-14-2009, 01:47 AM | #14 |
Re: Hydra-Boost
I'm thinking Astros had it too, check to see if anything in the yard has a 350 diesel in it,altho the powersteering pump is different.
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
12-14-2009, 01:57 PM | #15 |
Re: Hydra-Boost
my 84 k20 with a small block has hydro boost too.
12-15-2009, 09:18 PM | #16 |
Re: Hydra-Boost
You can buy reman ones just about anywhere. Don't waste your time putting on a used one. Its too much work just to find out it does not work and have to take it back. We sell reman ones from Cardone for just over $150.00 with a warrantee so that will give you an idea on price
Depends on the bracket that is on your truck they used two of them Last edited by mbgmike; 12-15-2009 at 09:21 PM. |
