Closed Thread
Old 12-09-2009, 11:24 PM   #426
198plus
198plus's Avatar
Re: What did you do to your truck today?
I'm no expert but from what I can find it is a factory tach......Maybe someone else could chime in on this ??????
Originally Posted by ol Curt View Post
You sure that's a factory tach?
Looks sweet either way! I really like the clock.
I have a set of those gauges. Some day I'll luck into a clock...probably from a Nova, and I might install it then. Without those two holes filled they look kinda bare.
198plus is offline
Old 12-09-2009, 11:28 PM   #427
ol Curt
Junior Member
ol Curt's Avatar
Me neither, just wondered. I thought I saw one in a manual once that was dash mounted. To tell the truth, that MAY have been where a factory clock was...either way, they look good.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline
Old 12-10-2009, 12:07 AM   #428
nbrfd007
nbrfd007's Avatar
Sat behind the steering wheel, made motor noises and drove like a 8 year old. Just dreaming!
nbrfd007 is offline
Old 12-10-2009, 03:07 AM   #429
sams60gmc
sams60gmc's Avatar
Well guys I've been Internet deprived lately because I've been trying to get setled into my new house. Last week I made my new rear frame rails out of 2x4. And ordered my bushings for my link bars on Monday. And today I rented a big trailer and brought the '60 to it's new home. Finally have a garage. It's a tight fit but will have more room after it's a shortbed. I'm just happy I finally have a semi warm and dry place that I can work on my truck in especially seeing as how it's been 14 degrees lately at night and thru the mornings. Well guys I get Internet Tuesday so I'll post tons of pics of my rear back half.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 12-10-2009, 11:44 AM   #430
DPowers
One foot in front of the other
DPowers's Avatar
Originally Posted by Captainfab
I recently bought a couple different sets of late model center caps after seeing this done on the '67-'72 forum. I see you used standard lug nuts. How did you go about attaching them to the ralley's?
I attached them through the holes for the ralleyes from the back side. The holes are large enough to use an impact on the original lug nuts which I like.[/QUOTE]
I used three #14-3/4 inch hex head machine screws that have a 3/8 socket head. I went through the 3 larger holes from the back side that the original caps were attached by and snugged them up with an air ratchet. They lined up well.
Last nite I removed all of the rear brakes down to the backing plates. Going to replace shoes, hardware, wheel cylinders, flex hose, brake lines, axle seals and differential gasket this weekend.
DPowers is offline
Old 12-10-2009, 03:43 PM   #431
joe231
joe231's Avatar
Originally Posted by SCOTI View Post
Details, details, details please. Who or where did you get it from?
SCOTI, have you seen this?
http://www.classicparts.com/1963-66-...ctinfo/24-735/
and it works with HEI...
yes that is the factory style tach, I really dunno how to tell if it is an original tach just by looking at the face though. I think the one from classic parts I posted is pretty much identical
CHEVY ONLY
joe231 is offline
Old 12-10-2009, 04:28 PM   #432
SCOTI
SCOTI's Avatar
Yeah, I've seen them. I still just have the standard 'idiot-light' panel vs. the optional 'gauge' panel. I need to first convert to the gauge panel (w/the necessary wiring) & then can add the tach set-up. Of course, that one has a clock too. It never seems to end $$$$$$$$$$$$$$$$$$$$$.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 12-10-2009, 05:11 PM   #433
198plus
198plus's Avatar
Never seen those, nice...........Wonder what I have to do to mine for it to work with HEI.......Is there some kind of resistor you can use ????????
198plus is offline
Old 12-13-2009, 05:54 PM   #434
lakeroadster
Added seat belts to the seat brackets I made a few weeks back.
lakeroadster is offline
Old 12-13-2009, 06:10 PM   #435
1stseries55
1stseries55's Avatar
i was browsing the FAQ section and came across this:
http://67-72chevytrucks.com/vboard/s...d.php?t=113397
i decided to make my own....i work at a plumbing supply house so mine is made out of schd 40 scrap but it worked out great.. alot safer than the 2x6 that i used to balance on my engine hoist to move the cab
I highly recommend this one
Jared
USMC 1st Battalion 8th Marines (95-99)
55 1st Series 3100 (on 98 sonoma frame)
65 GMC short bed fleetside big back window
http://67-72chevytrucks.com/vboard/s...d.php?t=358493
1stseries55 is offline
Old 12-13-2009, 07:14 PM   #436
jbgroby
jbgroby's Avatar
That's DAMN neat you might want to SERIOUSLY patten that and put it on the market. I'M SERIOUS.
jbgroby is offline
Old 12-13-2009, 07:19 PM   #437
62 short step
62 short step's Avatar
I agree, wish I would have thought about that when I did mine. I did the 4x4 thing, never again!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline
Old 12-13-2009, 07:30 PM   #438
joe231
joe231's Avatar
Try google.
I checked into it a couple years ago. Think you need a Zener diode and one or 2 resistors to make it work. If you hook it straight up to HEI it will fry the tach.
CHEVY ONLY
joe231 is offline
Old 12-13-2009, 08:47 PM   #439
Turkey
Turkey's Avatar
finished primering the bed rails and the rear bed panels. Also installed interior door panel after painting yesterday. Oh yeah, I drove it also.
Turkey is offline
Old 12-13-2009, 10:06 PM   #440
DPowers
DPowers's Avatar
Combining yesterday and today- installed new rear brakes w/new wheel cylinders, shoes, rear brake lines, new axle seals, new differential seal, painted the cover and put new oil in the differential.
DPowers is offline
Old 12-13-2009, 10:22 PM   #441
1stseries55
thanks fellas... but it was not my idea.. i just tweaked Solver's design to work with free crap I got from work. Yeah, using a 4x4 is a little scary...my 55 cab seemed much lighter so it was not as bad but the 65 was a little squirrely on wood.
Jared
Old 12-14-2009, 11:16 PM   #442
sams60gmc
sams60gmc's Avatar
Worked on my frame today for about an hour. Didn't get much done. Tomorrow I'll spend a few hours on it and get all my bracketry all done. I set up a tool to run in the mill to notch my 1/4" plate to fit my axle tubes really well. I'm really happy with the way things are turning out so far.
Old 12-14-2009, 11:30 PM   #443
70 Suburban
Rods
found that my holley base plate was/ is cracked
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline
Old 12-15-2009, 10:24 PM   #444
sams60gmc
sams60gmc's Avatar
Finally got the internet and some more work done on my rear backhalf.
Old 12-15-2009, 10:26 PM   #445
sams60gmc
sams60gmc's Avatar
Some more
Old 12-15-2009, 10:28 PM   #446
sams60gmc
sams60gmc's Avatar
1 more. This is my front crossmember. It will be a wishbone style rear end.
Old 12-15-2009, 10:37 PM   #447
ol Curt
Junior Member
ol Curt's Avatar
Originally Posted by kiknrocks View Post
i installed my trim
That trim looks great. Mind sharing where you bought it and if it all fit good?
ol Curt is offline
Old 12-16-2009, 11:04 AM   #448
70 Suburban
Rods
Rebuilt my edlebrock... .still no start .now i think all my plugs a fuel fouled
Old 12-16-2009, 09:38 PM   #449
sams60gmc
sams60gmc's Avatar
Worked on my end links a little today. Probably wont get much done til next week. Need to get 1 more bag then I can mock up the rear end.
Old 12-16-2009, 11:19 PM   #450
LILRED66
LILRED66's Avatar
It is a factory tach...I have/have owned several and they all look the same on the front and back. They are used on the six and V8 trucks, but I think they have a different setting on them between the two engine configurations, but I don't remember for sure.
LILRED66 is offline
Closed Thread
